Brakes for the C43
Old Feb 13, 2012 | 11:45 AM
  #176
popey24's Avatar
C43 AMG 5.5 - 396.4HP
Originally Posted by cm60k
Guys,
I think the "R129 SL500/600 98-2002 #: "129 421 21 12 or 23 12" are a closer measurements , if we need to replace ours.., but its little
heavier & needs some little mods. for the Pads isn’t ....??
ZAYED,,
You should insert a 1.5mm spacer between disc and hub for front wheels. It will also reduce the height of the centering cylinder that could bring some vibration (depending on your wheel).
Old Feb 17, 2012 | 06:36 AM
  #177
cm60k's Avatar
Thankss,, i installed the "R129 SL500/600" Rotors, they works great.....
ZAYED,,
Old Feb 17, 2012 | 09:20 AM
  #178
DRBC43AMG's Avatar
Any pictures please?
Old Feb 23, 2012 | 10:33 AM
  #179
cm60k's Avatar
I took some pics. with my friend iphone,, there not that clear....,, sorry, i well try to take another pics. later............
ZAYED,,
Old Mar 3, 2012 | 07:37 PM
  #180
importfan21's Avatar
1998 C43, 2017 Honda Accord Sport
Update: Got my slotted rotors in from BrakeLabs (eBay-based company). Zinc-coated. Gonna install these babies soon!
Old Apr 1, 2012 | 05:42 PM
  #181
cm60k's Avatar
Anyone knows whats the height of the SLK55 front Rotor Hat...?, is it 18mm....?? unfortunately i forget it......
ZAYED,,
Old Apr 2, 2012 | 02:05 AM
  #182
DRBC43AMG's Avatar
The problem with those is they are not two piece rotors like the "real" OE parts. Also check if they are directionally vented.
Old Apr 2, 2012 | 08:48 AM
  #183
You're correct, they are not 2 piece. They aren't directionally vented, but then again, neither were my OEMs. I haven't had a problem with them. I love 'em!
Those + the drilled front + Akebono pads rip my face off under heavy braking.
Old Apr 2, 2012 | 06:38 PM
  #184
503C43 ////AMG's Avatar
1999 C43, 2008 P30 E63, 2014 SQ5, 2024 Model Y Performance
The 99 C43 front rotors were directionally vented, I would be surprised if the 98's were not...
Old Apr 2, 2012 | 08:02 PM
  #185
We were talking about the rear rotors, silly.
My fronts OEMs were directionally vented.
Old Apr 2, 2012 | 08:05 PM
  #186
Old May 5, 2012 | 12:35 AM
  #187
Spragga's Avatar
C43
Originally Posted by thepinoc
Full bolt-on and plug-n-play with absolutely no problems My initial worries were completely baseless.
I'm about to try out this option as a means of getting drilled rotors on the front of my 98 C43 and wondering if anyone has heard of Apec brakes?
As well as the c230k 330 x 28 option they do a c230k AMG sport 345 x 30 which would appear to be a closer match to the original c43 334 x 32.
http://www.apecbraking.co.uk/catalog...w/item/1410717
http://www.apecbraking.co.uk/catalog...w/item/1410718
Based on the positive looking feedback I've seen regarding the 330 x 28 fit I'm going to give these AMG options a try. Other than these the ultimot rotors look the best like for like replacement so have them down as plan B.
I still like the original type II wheels with their retro classic look so my rotors will not be on show as much but still nice to have for the discerning eyes out there
Old May 5, 2012 | 04:10 AM
  #188
DRBC43AMG's Avatar
I agree for the Monos II and in 18"
Ultimot drilled rotors were my plan A and will be installed probably next week I confirm they are OE rotors but drilled for Ultimot. They even do drilled rear rotors. If I had not purchased the standard 300mm I would have taken these from Ultimot too
Old May 5, 2012 | 07:49 AM
  #189
Spragga's Avatar
C43
I do like the ultimot but the Apecs will save me more than £250 against these. I've read mixed reviews regarding Apecs but the negative ones relate more to track use which I don't do.
I wanted to check ultimot turnaround times and how much extra it is to ship to the Uk but my web browser gets errors translating their web site to English. So for now its nice knowing they exist.
I do believe cheap costs you twice in the long run and the last thing you want to be cutting corners on are your brakes but I've read enough to give these Apecs a try plus I've been promised next day delivery.
Regarding the type II wheels...I've tried different wheels over the years but always end up putting these back on....18's of course
Old May 5, 2012 | 09:57 AM
  #190
DRBC43AMG's Avatar
If you want the references just shout and they also respond to mails in English
Old May 5, 2012 | 11:41 AM
  #191
Spragga's Avatar
C43
Yes I may well take you up on this. the Apec 345 is a good 11mm bigger than the oem 334 but if they fit they'll fill up wheel nicely but then I wouldn't want them looking abnormal.
My thinking is if they can replace the 330 x 28 rotors on a c230k then unless anyone can advise differently they should be good to go on a c43 as well.
Cheers.
Old May 5, 2012 | 12:10 PM
  #192
DRBC43AMG's Avatar
Have you thought about the calipers? Going from 334 to 345 rotors may be too much for the caliper to clear the exterior of the rotor without interference. I'll look up the Ultimot reference numbers soon...
So here goes with the Ultimot references:
BS959 Rear rotors drilled 300 x 22mm at 193 Euros a pair (including VAT)
BS242 OE Front rotor (non drilled) 334 x 32mm at 465 Euros a pair (including VAT)
BS315 OE Front rotor drilled 334 x 32mm at 520 Euros a pair (including VAT)
VAT will be deducted from the price if parts are for export outside the European Community.
Old May 5, 2012 | 02:07 PM
  #193
cm60k's Avatar
Good point,,
Mostly can get like "2-4mm" clear space in calipers, but "34 to 45" is soo big , it well not fit & get a bad friction problem.......
ZAYED,,
Old May 6, 2012 | 08:45 AM
  #194
Spragga's Avatar
C43
Good point,,
ZAYED,,
Yes very good point Zayed/DMR and I did raise this with the seller as my concern was wouldn't AMG spec rotors come with complementary AMG calipers. They said as far as they know the AMG spec rotor fit the c230k without having to change the caliper.
I did wonder whether this was just salesmen plying their trade but to be fair to them whether bigger or smaller they are not supportive of the whole idea of putting c230k rotors on a c43 period and are quite intrigued to get feedback on how things work out.....maybe the standard c230k caliper is built with the necessary clearance to begin with.
I suppose my real danger is even if they appear to physically fit they'd really need to be driven to see how they perform which of course will violate the returns policy not to mention any other potential issue like the friction you mention, reduced lifespan or just fail to brake in general.
I haven't bought them yet so could still knock it on the head and get the 330 x 28's instead or just go where my heart really is and get the ultimots.
Old May 9, 2012 | 09:23 AM
  #195
Spragga's Avatar
C43
@DRBC43AMG - I've gone for the Apec 330x28. A physical inspection was enough to rule out the 345x30 as I couldn't see enough clearance to risk chancing it. If nothing else the feedback on this forum has served its purpose very well so thanks again for addressing this.
Ultimot seem to want a money transfer directly into a bank account as opposed to a secure payment like a credit card so again not worth the risk but the tax gain is quite attractive
I've just returned home so can now babysit this install more. The Apecs should be on the car by tomorrow so will provide feedback on fit and performance if they make it that far. At less than £53 + VAT each they're looking like a real bargain.
Old May 9, 2012 | 03:33 PM
  #196
DRBC43AMG's Avatar
True, you need to transfer funds to their bank account before shipment of the product. This is common practice with plenty of sellers and you sometime can negotiate a reduction in price as the seller has little or no charges to pay contrary to using a credit card or PayPal. Also, with electronic banking it is so easy. A couple of clicks and the money is transferred safely. In the case of Ultimot, the shipment was on the road 48h after I transfered the the funds
Old May 12, 2012 | 05:46 PM
  #197
Spragga's Avatar
C43
The apecs are looking good. They definitely fit (simply bolt on), and they definitely stop the car with a sharper bite so feel even better than the originals. I did get signs of overheating under very heavy braking but this appears to be due to the fact I used the same brake pads already on the car. Although used they are virtually new.
I've done some miles to let them bed in a bit and no longer see the 'fumey hot mist' when braking hard from speed. Will keep an eye on it but worst case I'll try some apec c43 pads.
If these rotors and pads have truly married then its really now a matter of seeing how durable they are and their productive lifespan though even if just for the short term these look perfect with the added bonus of since seeing them on eBay for £85 a pair and getting a price match - that's a saving of more than £400 against ultimot.
The Mercedes originals look to have come down since buying my last pair. I've been quoted £250 per rotor by the main dealer.
