A/C Help
1999 Mercedes-Benz C43 AMG
A/C Help
My ac was broke, so I had the compressor, dryer, and expansion valves replaced with all OEM parts. However, I still feel that it is not working properly. Im getting cool air, but not cold air. Yes, I know it takes awhile for a car with black interior thats been sitting in 95 degree temp for hours to cool down, but even after getting in it and driving it for 10 mins, its still hot im my car and the air coming from the vents is cool...not cold, almost as its just venting outside air. I've checked the refrigerant and its still fully charged. What could be the issue? Anyone know?
Location: Land of mountains, cheese, chocolate and watches
12' W204 C63 AMG coupe "T-Rex", 12' W451 Smart Fortwo Pulse (99' W202 C43 AMG sold)
Are you sure the compressor is working correctly? What about your pollen filter? Dry air canister? I'm not an A/C specialist, but I have had problems with the c240T: changed compressor, condenser etc. at the local MB garage. Works perfectly since 2 years now
I believe it is...this is my second compressor within a year because the first one was aftermarket and not OEM and the MB dealership said I had a bad compressor and that I need to get the DENSO OEM compressor....so I did. Its hard to believe I would get two bad compressors back to back. As far as my pollen filter...is that the same as the cabin air filter? If so, I have replaced that. What is the dry air canister?
Go to this webpage. The page has instructions that will tell you how to display the AC diagnostic codes. Post those codes in this thread and either myself or someone else may be able to help.
A US spec C43 climate control unit looks something like the attached photo. He says he has "no codes". Pressing and holding the rest button on an automatic climate control unit will display diagnostic codes. Many Euro spec cars don’t have the automatic climate control. They have manual climate control. Having manual climate control would explain the lack of codes.
I have one like that and its European, but with less buttons. I think the US and ROW all came with the led screen control module. The one in the picture looks like one from a CLK no?
![Red face](https://mbworld.org/forums/images/icons/icon11.gif)
cheaper versions of w202 mostly have manual AC, no reading codes on this AC
yes your ac can be perfect but if it is in limp mode cool air will come out but not cold, i replaced the condensor with a cheap one charged system still not cold, took it to an ac friend he calls and say i think you have a limp mode went over and reset it viola paid him 30 bucks to yep tell me it was in limp mode
1996 C36 AMG, 1995 Volvo 850 Turbowagon
never really had super cold a/c like the japanese cars... even after everything was replaced. it's cool, but just not freezing cold
![Question](https://mbworld.org/forums/images/icons/icon5.gif)
I have 97 E320 which blows warm air. Here are the codes i get can anyone suggest help? I already tried cleaning and lube the duo valve and added R134.
Sensors
1=31
2=28
3=59
3=50
5=41
6=88
7=00
8=42
trouble codes:
E FF
E61 232
Anyone have any ideas where to start?
Sensors
1=31
2=28
3=59
3=50
5=41
6=88
7=00
8=42
trouble codes:
E FF
E61 232
![](https://mbworld.org/forums/members/marcusf-albums-marcusf-picture603-cold.jpg)
Chels97 - #7 tells you the Freon pressure. When it's zero, it's usually empty.
