I thought our cars couldn't do this??? Pix inside.
Old Jun 1, 2011 | 08:39 PM
austinholloman's Avatar
W203 C55 and SAAB 9-3 2.0T
Shouldnt you need an LSD to lay down these tracks??? First time ive ever shut off the traction control...
Old Jun 1, 2011 | 09:51 PM
PC Valkyrie's Avatar
C55 AMG, 135i, 911 GT3, GLE43 AMG
Yes, it is a myth that you MUST ABSOLUTELY have a mechanical LSD to do a 2 wheel burn out. It's amazing how many people on this (and other) forums buy into this myth. I've done this on my W203 C55 too, and I also don't have a mechanical LSD (just the electronic pseudo LSD when I press the "ESP off" button).
If both wheels have similar traction, then both wheels will spin and lay down 2 strips of rubber. If one wheel has noticably less traction than the other, then the open differential will direct more power to the one with less traction, causing one tire spinning excessively more than the other and then laying down potentially one strip of rubber. Modern electronic traction control systems may minimize this to an extent.
Old Jun 1, 2011 | 10:34 PM
503C43 ////AMG's Avatar
1999 C43, 2008 P30 E63, 2014 SQ5, 2024 Model Y Performance
AUSTIN WHERE HAVE YOU BEEN??!?!?!!!?!?!?!
Looks like you were doing some burnouts in a neighborhood
P.S. WHAT TOOK YOU SO LONG TO TURN THE ESP OFF????
Old Jun 2, 2011 | 06:08 AM
LawRens's Avatar
43
lol my traction control is permanently off. and the best part is, i don't know why.
Glad to see AH is alive and kickin'. Nice tracks!
Old Jun 2, 2011 | 07:15 AM
KJI3jflarryfe93's Avatar
your ESP: did you remove the fuse or do you have a glitch somewhere in the ECU?
If your MAF and o2 sensors are healthy you will notice how powerful your car is when you stomp the axxelerator!
my C43 has worn out rear tires and I constantly get the ESP to flash when I do a hard axxeleration from stand still.
I love my C43 being sooooooo torqey.
The MGM lion roars from my tailpipes when I hit the axxelerator!
Old Jun 2, 2011 | 10:59 AM
Shadow5501's Avatar
Car free at the moment
Short answer: You are correct, an open diff spins only one tire. Texans get to see this all day long, as pickup truck drivers gun it while making a right turn.
Longer answer: The ESP is not completely disabled even when "off." It won't cut the throttle on you, but still applies brake force to a spinning wheel. With an open differential, braking one wheel causes torque to be sent to the other, unbraked wheel. On your Benz, this causes torque to be more or less evenly applied to both rear wheels. Hence both spin. You may even be able to feel the brake pulsing and modulating the torque to each rear wheel.
Old Jun 2, 2011 | 12:23 PM
ECTurboGSX's Avatar
98 C43, 15 Alfa 4C LE, 18 Tesla Model 3 DM Perf, 08 Duc S1000, 02 Duc 998, 98 Duc 748, 01 Miata
I think the white van did it....
Old Jun 2, 2011 | 12:24 PM
hoontastic's Avatar
99 c43 / 99 ml430
these cars would be so awesome with a factory 6spd manual and lsd option..
Old Jun 2, 2011 | 07:39 PM
Jasssc's Avatar
1996 Mercedes C36 AMG
Those are the two things that need replacing on my car right now!
Old Jun 2, 2011 | 11:17 PM
Yup, that van has a 63 motor coupled with a quaife LSD and eats tires for breakfast
Old Jun 2, 2011 | 11:19 PM
hoontastic's Avatar
99 c43 / 99 ml430
dont talk about quaifes it just makes me sad
Old Jun 2, 2011 | 11:57 PM
Yes im alive. LOL Ive been so busy here in the south with two jobs and school. And yes that little orange triangle gets a hell of a work out but this was the first time I tried with it off... I was pretty shocked at the out come.
Old Jun 4, 2011 | 01:38 AM
Steve155's Avatar
1999 C43 AMG
AH, looks like a sweet burnout! If you ever make it to LA you'll have fun - traffic does suck at times, but the highways just book - I'm regularly cruising the fast lane at 80 to 85 - hit triple digits more than I should! Then there's Mulholland Hwy which is a blast! Anyhow, glad to hear all is well and keep those burnouts going!
Old Jun 4, 2011 | 04:49 AM
DRBC43AMG's Avatar
Welcome back! Still got some tyres after the burn out?
Old Jun 4, 2011 | 06:04 AM
Motorsport3's Avatar
Dynocomped C43K, 08 X5
Hey!! Austin! It's been a long time!!!
BTW: did anyone get the wavetrac lsd yet???
Old Jun 4, 2011 | 06:13 AM
That picture looks so nice with 35mph sign in the background
Old Jun 4, 2011 | 01:31 PM
Austin, how is your camber on the rear wheels? Looking at your tracks it looks like you are getting more contact towards the inside of the rim (i.e negative camber)
Old Jun 4, 2011 | 01:45 PM
Ask SLK, he was the one who was going to get one. I am interested in the final result as well
Old Jun 9, 2011 | 01:51 AM
tri-star tech's Avatar
2004 CLK55
I think a 722.9 with a wet clutch would be better or an SLS transaxle (No human can shift as fast as that thing can)
Old Jun 9, 2011 | 09:19 PM
Oh yeah, they lean in pretty bad with no spacer or rear camber kit. Haven't seen anything too bad with the wear yet but im sure I will.
