Car turning over but not starting
Old Jun 4, 2011 | 02:24 PM
nick3453's Avatar
1999 Mercedes-Benz C43 AMG
Just recently when I go to start my car it will turn over but not start. It takes about 10 times plus working the gas pedal to get it started. Once started...it runs great. Just had my plugs and o2 sensors replaced. Any ideas what could be the cause and how I can fix it?
Old Jun 4, 2011 | 02:38 PM
hoontastic's Avatar
99 c43 / 99 ml430
crankshaft position sensor?
Old Jun 4, 2011 | 03:02 PM
nick3453's Avatar
Should I get the CEL and a code if its that?
Old Jun 4, 2011 | 03:03 PM
hoontastic's Avatar
99 c43 / 99 ml430
probably.. also our cars are sensitive to voltage. It may be as simple as an end of life battery.
Old Jun 4, 2011 | 03:10 PM
nick3453's Avatar
oh..I also just had my battery and start checked out...they are both good. Maybe its the fuel pump going bad. Ive read that you can check that by connecting a fuel pressure gauge to the fuel rail?
Old Jun 4, 2011 | 03:16 PM
DRBC43AMG's Avatar
I thought the CPS allowed the car to start when cold but refused when hot. At least that was what happened with mine last year.
Old Jun 4, 2011 | 05:14 PM
503C43 ////AMG's Avatar
1999 C43, 2008 P30 E63, 2014 SQ5, 2024 Model Y Performance
You need 3 things for your engine to run:
1.) air
2.) fuel
3.) spark
air is almost a given so I always start with spark as it is the easiest to determine if it is not functioning properly then I move onto fuel and end with air.
Check to see if you are getting spark from the plugs then I would check the fuel pump.
The fact that you have to pump the pedal like your AMG was made in the 60's is puzzling
Old Jun 4, 2011 | 06:01 PM
nick3453's Avatar
lol...i know right. Like I said earlier, I just replaced my plugs and O2 sensors. Its wierd...runs like a beast once its started....so im kinda iffy on the fuel pump being the prob because wouldnt not run good...or at all...if the fuel pump was bad?
Old Jun 4, 2011 | 07:51 PM
I wouldn't rule anything out until you have confirmed that it is in PERFECT working order, I have seen odd problems in the past that made NO sense. Since you JUST replaced your plugs and O2 sensors perhaps you may want to start there.
I would start like I had suggested and systematically start eliminating each variable, otherwise take it to a shop...
Old Jun 10, 2011 | 02:20 AM
E2.3's Avatar
C43
The EXACT same thing happened to my C43. It was the CPS. Never had a problem starting since (three years). Very easy to access and install (one bolt). Under 100 bucks. Good luck.
Old Aug 30, 2011 | 02:00 PM
98 MBC43 AMG's Avatar
98 MBC43 AMG
im having problems starting my c43 amg 98
it start like it wanna turn over but then it stops aft 5second but it never start it turn over but never start what yall think is the problem. it has 185,000 miles n 3months ago i did fuel filter, oil n filter change, a fuel drip from a license dealer they said the spark plug was still good im almost do for another oil filter change. can sumone help me figure out whats wrong with my AMG
Old Aug 30, 2011 | 03:22 PM
DRBC43AMG's Avatar
Get the codes pulled and checked. If anything is wrong you will know then.
Old Aug 30, 2011 | 03:59 PM
98 MBC43 AMG
EVEN IF NO CODES SHOWED UP ON THE DASHBOARD
Old Aug 30, 2011 | 04:16 PM
DRBC43AMG's Avatar
Yes, codes can be stocked without warning light on the dash. You need the car plugged into a Star diagnosis system.
Old Aug 30, 2011 | 04:52 PM
98 MBC43 AMG
THANKS MAN FOR THE INFO I WILL LET U NO WHAT IT WAS THANKS AGAIN
Old Aug 30, 2011 | 05:31 PM
RPB's Avatar
RPB
Sounds like CPS but check codes too, gl w/ that.
Finally not a thread about the 5spd trans.
Old Sep 1, 2011 | 04:14 PM
98 MBC43 AMG
hey guys my car started up ran for 5mins and put in drive wit out pushing gas it rolled on its own but when i hit the gas it shut off and wont turnover again. i tryed everything yall said from cps put it on the machine coder nothing **** up battery tested still give out 900 cranks. anybody got any other suggestion plus thanks in advance guy.
Old Sep 1, 2011 | 04:18 PM
DRBC43AMG's Avatar
Guess you have no option than to give it to a workshop and get some professional help
Old Sep 1, 2011 | 04:31 PM
98 MBC43 AMG
Unhappy
thanks friend
Old Sep 2, 2011 | 12:02 AM
MarcusF's Avatar
2002 CLK430
I agree with Hoontastic. How old is the battery? A day over 4 years and I'd toss in a new one without a second thought.
Old Sep 5, 2011 | 07:43 PM
98 MBC43 AMG
hey guys it was my fuel filter and i brought it new three months ago so i put a new fuel filter and fuel pump cost me $320 for both. shes back to running like a beast all over again. the fuel pump was the original part so i jus change it with labor $420 THANKS FOR THE HELP YALL
Old Sep 6, 2011 | 02:45 AM
KJI3jflarryfe93's Avatar
great it worked out for ya.
driving your car is addictive
always use MANN or MAHLE fuel filters, top notch quality
and 4 the rest of the car stick with HQ branded parts,
Old Sep 6, 2011 | 03:40 AM
DRBC43AMG's Avatar
If I understand correctly, the filter was changed 3 months ago. If it was clogged again, I guess you have a large amount of muck in the tank. That probably needs a good flush and clean, otherwise you are going to have the same problems soon....!
Old Sep 6, 2011 | 12:32 PM
98 MBC43 AMG
yes thats correct but how do i go abt getting the gunk outta the tank
Old Sep 6, 2011 | 01:43 PM
drain that sucker, and suck it out
