C43 Timing Chains?
Old Jun 14, 2011 | 12:37 AM
Benzonline's Avatar
99 C43 ///AMG
C43 Timing Chains?
Hey guys, whats the story with timing chains on the C43s I hear they are "lifetime"? Ive dealt with a snapped timing chain on a Benz V8 before (old 380 crapola) so just wondering about the C43 I have now with approx 90k on it.
Only symptoms of "sound" I hear now is when its cold, there is a tapping sound coming from the engine for about 3 mins and then it fades away as this "part" get its lubrication from the oil finally. Father says it could need a new timing chain tensioner and the chain is possibly slapping? Sounds iffy and scary.
Im going to the shop this weekend however want to know some opinions. Car is otherwise doing fine.
Thanks!
Old Jun 14, 2011 | 01:33 AM
503C43 ////AMG's Avatar
1999 C43, 2008 P30 E63, 2014 SQ5, 2024 Model Y Performance
Thanks!
I checked the WIS and it didn't mention anything about having a certain mileage/amount of time that the chain needed to be replaced at. I did find the WIS instructions on how to replace the chain if you are interested...
Old Jun 14, 2011 | 02:50 AM
DuaneC63's Avatar
AMG GLC63. Audi R8
I'd replace if there is any doubt in your mind. The thought of valves kissing piston heads is not very appealing.
Old Jun 14, 2011 | 03:56 AM
KJI3jflarryfe93's Avatar
c43's might have problems with their timing chains if them cars are high mileage.
You'll hear some rattling from the chain, also it gets slacked.
Old Jun 14, 2011 | 09:47 AM
Benzonline's Avatar
99 C43 ///AMG
Problem is, I dont have high mileage and what is this valve like tapping sound upon cold startup for 3 mins?
Old Jun 15, 2011 | 01:13 AM
MarcusF's Avatar
2002 CLK430
That noise is typically from the purge valve. On a CLK it's located up front near the ABS spider's nest. The purge valve is labeled MOT. I know I've posted photos of where it is before, but I have no idea what forum or even which website. A search on "MOT tapping" may reveal a photo.
Old Jun 15, 2011 | 01:49 AM
Benzonline's Avatar
99 C43 ///AMG
I recognize purge valve noise. Thats different. This is more like a valve knocking type sound for 3 mins.
Old Jun 15, 2011 | 04:36 AM
DRBC43AMG's Avatar
Could be the lifters tapping until filled with oil. What type of oil are you using? Could also be the oil used is too heavy on cold start ups.
Old Jun 15, 2011 | 09:46 AM
Benzonline's Avatar
99 C43 ///AMG
Mobil 1 0w-40.
Forget it guys ill have it figured out.
Old Jan 2, 2014 | 10:14 AM
c230kris's Avatar
1999 C43 AMG
Mobil 1 0w-40.
Strong bump
So WHAT was it?
Old Feb 2, 2023 | 07:09 PM
Badams's Avatar
2017 Mercedes Benz C43 AMG
Yes, can you please put in the instructions. I have a 17 C43 with 54k miles on it and local garage is telling me tensioner needs replaced and most likely timing chain. I have the same rattle at start last about 5 seconds. However I have the P0016 code as well. I'm trying to find more info on how to change the timing chain and specific tools needed. The Mercedes dealer is rough quoting $6k to $9k
Old Feb 4, 2023 | 04:39 PM
This is the W202 C43 section. The WIS I have doesn't include vehicles from 2017. Check the other C43 forum
