Transmission sticks in third on highway!
Old Jul 22, 2011 | 01:38 PM
austinholloman's Avatar
W203 C55 and SAAB 9-3 2.0T
If I don't have my tranny in "W" mode, it's stick in third.... Any ideas? Please god don't tell me I need a new one. It's runs fine in "W" but acts really weird in "S" mode.....
Old Jul 22, 2011 | 05:33 PM
w202mylove's Avatar
Carlsson CM60 EX:C36AMG'96
Nothing wrong in s it changes gear at red line not before that.
Old Jul 22, 2011 | 07:13 PM
503C43 ////AMG's Avatar
1999 C43, 2008 P30 E63, 2014 SQ5, 2024 Model Y Performance
Did you try the ECU reset (or TCU reset, whatever you call it) ?
I know there is a micro switch that controls the switch from W to S, it is connected to the electronic gear recognition switch but I am unsure if you could replace it by it self. The whole unit (electronic gear recognition switch) is around $100 from the dealership.
I would try the reset first as it won't cost you anything.
Old Jul 22, 2011 | 09:49 PM
How do you reset it?
Old Jul 22, 2011 | 11:26 PM
importfan21's Avatar
1998 C43, 2017 Honda Accord Sport
Sounds like you have my problem, as I have yet to fix it (except mine does it in W and S mode).
I've done:
  • Filter/fluid/gasket change (and adapter plugs too since they were leaking)
  • TCU reset
My problem is temperature related, as it won't shift out until the engine warms up (~10 min/miles).
TCU reset instructions:
1.Turn key to position 2 (on position)
2.Floor (hold) gas pedal for 5 seconds. Turn key to position 0 (off). Don’t remove key. Release gas pedal. Don’t open doors, windows, etc.
3.Wait 2-3 minutes for computer to reset. Start car and drive aggressively for approx. 10 miles. The computer will 'tailor' itself for a more aggressive performance.
Let me know if you find a solution/have similar symptoms like me.
Old Jul 23, 2011 | 12:42 AM
I've done:
  • TCU reset
I can't remember, do you have to hit the kick down switch or not?
Old Jul 23, 2011 | 08:42 AM
Yes, you have to hit it.
Old Jul 23, 2011 | 12:48 PM
justinwrock's Avatar
Ducati
Try "jockey shifting" it... (Manually upshift through the gears starting in first.)
My C is driven very aggressively, and will hold all of its gears till redline if I leave it in drive.
Old Jul 24, 2011 | 02:12 PM
None of this helped. The only way it will shift like it use to is if I use winter mode... Pissed.
Old Jul 24, 2011 | 06:53 PM
You changed the ATF [already]?
Try letting your engine warm up a bit (like it's wintertime) then go out and see if it gets stuck. Mine's temp related but I'm not sure why or what.
Does yours ever shift out of 3rd at all?
Old Jul 26, 2011 | 09:01 PM
I think mine is temp related also.... If I let it warn up it's fine.
Old Jul 26, 2011 | 09:25 PM
Well it's good (not really good, but you know) that you have the same problem I do. Only things I could think that are related to temp is the ATF fluid and the cats. I've changed the fluid, so the only thing left for me to try is to replace the cats.
Wish I knew what the problem was...
Old Aug 4, 2011 | 04:41 PM
Frank Castle's Avatar
C43
ATF level is full? I know when mine dipped low it acted up.
Old Aug 4, 2011 | 09:25 PM
Mine ended up being because I was running in my spare?? It's was in the front pass side. It's a 17 and the rest are 18... Major fail. Lol
Old Aug 5, 2011 | 04:45 AM
DRBC43AMG's Avatar
From: CH = Land of mountains, cheese, chocolate and watches
Jeez man, how can that happen
Old Aug 5, 2011 | 06:47 PM
Now that you mentioned that, I think that was the cause of my problem too. I had to throw the spare on front driver's side when I got a flat, but the spare is the same size as the fronts, correct? Then when I got my new wheels on (no more spare on), that happened right when the heat wave hit, and my problem went away.
WEIRD.
Old Aug 6, 2011 | 11:47 AM
Benzonline's Avatar
99 C43 ///AMG
Phew! All cause of a spare! Don't you just love these cars Life is Good with a C43
Old Aug 6, 2011 | 11:49 AM
KJI3jflarryfe93's Avatar
could it be because of the wheel geometry was wrong?
and the trans burned or something?
Old Aug 6, 2011 | 02:01 PM
If it were on the rear axle, I'd say maybe. Even then, maybe it'd affect the differential, not the transmission. Also, I was running stock wheels front/rear when I had my problem.
But the front axle?! Seriously?! This was the most frustrating troubleshooting I've ever had to do!
Old Aug 6, 2011 | 03:45 PM
DRBC43AMG's Avatar
ABS perhaps?
Old Aug 6, 2011 | 09:51 PM
MarcusF's Avatar
2002 CLK430
All four wheels are used to determine vehicle speed and the TCU knows vehicle speed. If one wheel is rolling at a different speed than the others, it seems likely the TCU would know that something is wrong.
Old Aug 7, 2011 | 10:32 AM
Marcus is correct as usual... If you replace your front pads or rotors you can see the speed sensor connected to both of the front hubs.
The one thing I don't get is why don't we see issues when doing a burn out or power slide around a corner? The rear wheels are traveling MUCH faster than the fronts and I would expect to see a similar issue when this occurs
Old Aug 7, 2011 | 10:37 AM
when often doing burn outs, you stress the transmission and will eventually burn clutchpacks also destroying the rear axle
Old Aug 7, 2011 | 04:29 PM
DRBC43AMG's Avatar
Bad Boy attitude
Old Aug 9, 2011 | 01:40 AM
My car is running like a dream... Time to start 5.4l shopping for a rainy day.....
