tip-tronic in pre-2000 models
Old Oct 12, 2012 | 01:01 PM
  #101
trinitony's Avatar
E55 C43 993C2S
Is this mod really worth the trouble?
I rarely use mine on this car....
Old Oct 12, 2012 | 01:44 PM
  #102
cm60k's Avatar
Is your C43 with Tip-tronic....??
ZAYED,,
Old Oct 12, 2012 | 04:45 PM
  #103
amg4.3's Avatar
C43 AMG
Zayed do you have any info on the wiring?
Old Oct 12, 2012 | 10:58 PM
  #104
cm60k's Avatar
Unfortunately i didn't remember a clear spes. for wiring installation,, i told my friend to send any pics. he had for that Tip- installation & he sent "3" pics.,, but as far as remember i only changed "2" connectors(Recognition switch & Reverse wire),,
tip-tronic in pre-2000 models-image4.jpgtip-tronic in pre-2000 models-image3.jpgtip-tronic in pre-2000 models-image2.jpg
ZAYED,,
Old Oct 13, 2012 | 05:07 AM
  #105
amg4.3's Avatar
C43 AMG
Did you have to buy new connectors?
Which pins do the wires go in the gauge cluster?
I will have to get this info as it impossible guessing which wire goes where
Old Oct 13, 2012 | 07:08 AM
  #106
cm60k's Avatar
As i mentioned before,, there’re a different models & versions of the gear harness,, im not sure which version AKA wires in your car, you have a
better idea than the one i did,, if one of those CLK320 you found has a Tip., you can simply take it with a gear harness either,, that will make the
things easy to you, better to not loosing time of connections & wiring job, like we did....
ZAYED,,
Old Oct 13, 2012 | 07:10 AM
  #107
amg4.3's Avatar
C43 AMG
I have ordered a new one from dealers. So i will have to do with that now as they wont take it back.
Old Oct 13, 2012 | 07:30 AM
  #108
cm60k's Avatar
Did you ordered the Tip Shifter or the gear Harness.....??
ZAYED,,
Old Oct 13, 2012 | 07:32 AM
  #109
amg4.3's Avatar
C43 AMG
Gear harness i ordered from dealer. Shifter i will be getting on monday hopefully
Old Oct 13, 2012 | 07:34 AM
  #110
cm60k's Avatar
Which gear harness you ordered..?, is it the same one you have in the car....??
ZAYED,,
Old Oct 13, 2012 | 07:35 AM
  #111
amg4.3's Avatar
C43 AMG
I ordered the one you gave the part no for?
Old Oct 13, 2012 | 07:41 AM
  #112
cm60k's Avatar
Do you mean the Cluster indicator cable. #: "203 267 00 64"....??
ZAYED,,
Old Oct 13, 2012 | 07:43 AM
  #113
amg4.3's Avatar
C43 AMG
Yes thats the one i ordered. Do i need another harness?
Old Oct 13, 2012 | 08:05 AM
  #114
cm60k's Avatar
This is NOT the gear harness,, this cable for ignition lock & shows the position of the gear selector you desired in the Cluster,, the gear harness is the main wires connecting from the shifter to the TCU goes to the main Trans. plug,,
I didn’t give you the Harness # before, cause i thought there is a good Electrician around you can do the connections,, don’t worry about that, just you are lucky to find a CLK320, you can take the Harness right away,,
By the way: the Harness should comes with #: "202 440 69 09", or "202 440 70 09".
ZAYED,,
Old Oct 13, 2012 | 08:45 AM
  #115
amg4.3's Avatar
C43 AMG
So the wiring has to be changed aswel?
Old Oct 13, 2012 | 12:19 PM
  #116
amg4.3's Avatar
C43 AMG
Zayed can you please confirm this?
Old Oct 13, 2012 | 03:14 PM
  #117
cm60k's Avatar
Sure my friend,, if you change the wires, that will make things easier to you,, as i told you: unless if there’s a professional garage that has
an Electrician can do the wires & connectors swap.....
ZAYED,,
Old Oct 13, 2012 | 03:18 PM
  #118
amg4.3's Avatar
C43 AMG
Zayed im confused why does the wiring need to be changed? We are not changing TCU so why change wiring. If we changed TCU then i understand the wiring needs to be changed
I will be doing this mod my self
Old Oct 14, 2012 | 12:02 AM
  #119
cm60k's Avatar
See, all W202 & W208 comes with a different versions of wiring harness, im not sure which version you have, when i pulled out my friends C43 wires i noticed he got a different version than i do,, although we have a same 98 C43s models & spec.,,
All TCUs has the same pins & connectors, the wiring which i talking about for the Tip shifter it self,,
Some of the earlier Tip wires has a minor different than the one we have, but some of late version of the Tip wires has more different,, that’s why i cannot confirm which version of wires you have, need to pull them-out & see.....
ZAYED,,
Old Oct 14, 2012 | 03:28 AM
  #120
amg4.3's Avatar
C43 AMG
Ok i see zayed the part numbers 202 440 69 09, or "202 440 70 09" are these what i need to look out for? If i have these part numbers i don't need to change wiring is this correct?
Old Oct 14, 2012 | 03:51 AM
  #121
cm60k's Avatar
These part #s for the Tip shifter, NOT for the one you have,,
Do you ordered the Tip shifter from CLK320...?, if so, which model is that...??, and is it from the junk yard.....???
ZAYED,,
Old Oct 14, 2012 | 04:19 AM
  #122
amg4.3's Avatar
C43 AMG
Yes its from clk 320 and its from junk yard. I e mailed the guy about the part no but he hasnt got back to me. He hasn't taken it out of the car yet
How will i know which harness i have?
Old Oct 14, 2012 | 04:35 AM
  #123
cm60k's Avatar
Did he told you which model of that CLK320......??
ZAYED,,
Old Oct 14, 2012 | 04:37 AM
  #124
amg4.3's Avatar
C43 AMG
I think its 1999 model
Old Oct 14, 2012 | 04:42 AM
  #125
cm60k's Avatar
That’s good, if you can tell him to send the wire from the same car it well be great.....
ZAYED,,
