C43 Suspension Lower on Driver Side......
Old Aug 5, 2011 | 06:03 PM
FREDC43AMG's Avatar
AMG
Ive find out very little discussion about our C43 being lower on the driver side. This is my 3rd C43,and trust me springs are well installed and still have driver side being lower.Anyone of you have had this problem or have found a way to avoid this,i know its probably heavier because of many things but hey i dont want to start putting different pads sizes on the sides! Im running H&R Super-Sport & #1 all around,Its more noticable on the rear ..... Thanks In advance. Fred.
Old Aug 5, 2011 | 07:06 PM
503C43 ////AMG's Avatar
1999 C43, 2008 P30 E63, 2014 SQ5, 2024 Model Y Performance
I just went out and measured both sides and mine are equal
Old Aug 6, 2011 | 01:59 AM
cherokee94nz's Avatar
2006 C55
mmmmmmm do they call you Big Fred.
Old Aug 6, 2011 | 04:11 AM
DRBC43AMG's Avatar
Mine sits perfect on all corners and I weigh 95kg (yes I know I have to loose some weight, but life is too short for this kind of hassle)
Old Aug 6, 2011 | 05:51 AM
Saaboteur's Avatar
eclectic assortment of cars
In what condition are your shocks? If they are worn out, you could have some ride height issues. Also, how much if a difference are you talking about? There could be some variation in the fenders - those holes for the fasteners can lead to some variation too.
Old Aug 6, 2011 | 06:13 AM
KJI3jflarryfe93's Avatar
on certain even pavement places my car sits lower on passengers side rear.
on other places it sit straight level???
WTF!
It's strange that my car is leaning on the passengers side sometimes?
Old Aug 6, 2011 | 12:32 PM
WTF!
I question how level the pavement is if this only occurs sometimes and other times your car sits level...
Old Aug 6, 2011 | 01:44 PM
yeah, i know it sounds weird!
the other day when my car was parked outside my house, it was leaniiiing to the right passengers side!
the other day when I snapped a few pics of the rear it had even level stance on another place???
WTF!
pavement on both places was even level, wweird
Old Aug 6, 2011 | 05:46 PM
w202mylove's Avatar
Carlsson CM60 EX:C36AMG'96
I have got the same problem, i dont understand how it is possible.
Old Aug 7, 2011 | 06:09 PM
FREDC43AMG's Avatar
AMG
Im currently running on stock shocks...wich have probably never been changed and the guy who had it for the last 10 years was driving it lowered too... They seems to be okay but are getting a little rusty! I tought i shoudnt worry about shocks since they dont really change the ride height i guess i was wrong, my older C43 with higher milage was leaning on that side too and was on old stock shocks too.The difference of height is not major but i notice it every time a look at it something like half a inch on the back and 5 mm on front.
I see alot of you guys change their shocks for the Bilstein Sport.. arent they the same as the stock Bilstein we have?
Old May 13, 2013 | 10:05 PM
Dziner82's Avatar
99 C43 AMG, 2001 CLK55 AMG
just to continue this topic, seems there have been a few threads like this but no resolution...
I just had my bilstein sport springs installed today. I get home and notice the leaning, about 5/8" higher on the driver side rear, or basically 3 fingers driver side and 2 fingers passenger. car was 2 fingers both sides before install (euro springs). the front is level, or ar least level enough to the naked eye.
i dropped the car back off at the shop after hours and left a note explaining, i will keep this thread updated on what i hear back tomorrow. But the springs and spring pads are only about 8 months/3000miles old, so that shouldn't be the issue. i know its random but i thought it could be possible that when they pulled the springs/shocks/spring pads that they might have put one of the fronts on the rear, etc but that would throw the front off too i would think, but who knows.
Its supposed to be the best German Auto shop in town so we will see how this goes. I will flip my lid if they try to pull the "we only installed your parts, we aren't responsible for what happens after they are on" card since they gave me the story about customer supplied parts.
Old May 14, 2013 | 07:57 AM
DRBC43AMG's Avatar
I think I may have a solution to this question
When installing my KW adjustable suspension, I noticed on the front lower suspension arms there is not a cut out position to place the end of the spring spiral, so depending on where the end of the spring is positioned on the arm, it will give a different height when you put the vehicle down on its wheels.
The rear is no problem as there is only one way to install the springs due to the built in cut away in the lower suspension arm.
I stand to be corrected but I think this is the answer to a recurrent problem experienced by many owners ...
Old May 14, 2013 | 06:47 PM
nd4spd13's Avatar
1995 C36 AMG, 1998 C43 AMG
There is definitely a spot for it on mine. I don't have a pic of my actual arm, but you can see it here
Old May 14, 2013 | 10:17 PM
koich's Avatar
1998 Black Opal C43
I got the same problem!! Driver side rubs on the fender but passenger side doesn't. I don't think mine is a spring sitting issue though. Planning to swap out my spring pads with left and right to see it makes a difference.
Old May 15, 2013 | 05:58 AM
DRBC43AMG's Avatar
Interesting, I didn't notice that... Perhaps I'm getting too old
Old May 15, 2013 | 11:44 AM
FREDC43AMG's Avatar
AMG
I started this thread a while back ago... And still never understood why mine was leaning to the driver side. Had 3 C43's and the last one was the more noticable,took suspension apart many time and everything seemed ok... New H&R coil Springs and New Bilstein shocks didnt change anything. As for the way the Tip of the springs sits on one side and the other might change a little bit the eight because it sits on the opposite on each sides but never saw that on any other cars soo...? It might also be due to more weight on Driver side?? Anyways the best solution is to Put thicker Pads on the side wich looks lower,pads were actually created for this particular reason. I know have a w211 E63 and still have this type of problem and many others as comfirmed noticing lower driver side,might be a German Thing to make car sit straight and level on highways.
Old May 15, 2013 | 04:06 PM
maybe your springs got soggy and sagged over the years?
on certain pavement conditions mine is leaning a bit on the passengers side.
in other places it's sitting straight.
WTF?!
maybe springs gets weaker dropping their stiffness?
Old May 15, 2013 | 07:37 PM
Pagz's Avatar
C43 w/clk55 Organs
for equal level it is super important to do all the suspension bushes up while the car is flat on the ground. you will see all the bushes have line up marks which must be straight or lined up when the car is level!.
This can be akward to do so I actually ended up making 6mm steel plates with little nylon wheels which I used to bolt to the hub and drop the car on, which allowed easy access to all the bushes. alternatively a car hoist is needed.
Old May 28, 2013 | 10:00 AM
Dziner82's Avatar
when i took my car back to the shop they redid my alignment, mostly because my steering wheel wasn't straight, not due to the leaning, but when they rechecked it after they only noticed a 1/4" difference (driver side being higher), whereas prior i had measured the difference at 5/8"
so its not much of a lean anymore, which i guess i am ok with. also mine was in the rear.
