W202 Engine Swap??
Old Jun 4, 2003 | 01:37 AM
nicee's Avatar
W202 Engine Swap??
Does anyone know what motors will fit into a W202 chassis? What is the biggest motor that will fit? The C55 is the same motor that is in the E55 right? will those two fit? and will a '99 S500 motor fit? If anyone can tell me which engines and from what models and years will fit into the W202, I would appreciate it. Thanks. Any comments or ideas where to find engines also welcome.
Old Jun 4, 2003 | 02:30 AM
Eurosport's Avatar
monowiper
5.5 L will fit np
you'll see it on my car sometime in the near future or distant future
Old Jun 4, 2003 | 10:54 PM
Denlasoul's Avatar
1998 C43
Hmmmm......Think you'll keep up with my C43K? LOL
Old Jun 4, 2003 | 11:56 PM
speedybenz's Avatar
AMG C43, 1999
I will smoke you both as soon as we hit a couple of corners. Just look to the left as I drive by you on the outside.
Jeff
Old Jun 5, 2003 | 12:11 AM
Denlasoul's Avatar
1998 C43
No doubt Jeff. Liek the saying goes: "Power without control is nothing."
But, you keep revealing you're secrets to us. You are probably a much better track person too.
One of these days...(shakes fist)....I'll get you Mister! LOL!
DLS
Old Jun 22, 2003 | 01:52 AM
MikeL's Avatar
Uber 202
BRABUS 5.8L V8, but in any engine swap, you would have to swap the tranny too..
Old Jun 22, 2003 | 06:21 AM
Eurosport's Avatar
monowiper
brabus 5.8L is how much? last i heard it was more like 4 years ago it was expensive as hell compared with other options
Old Jun 22, 2003 | 05:10 PM
MikeL's Avatar
Uber 202
very expensive, i went to Newport beach where Brabus is, and a rough estimate, engine, tranny, and labor, was about 80K.. mite as well buy a new car.
Old Jun 23, 2003 | 02:52 AM
Eurosport's Avatar
monowiper
80k is ridiculous
you can buy a lot of mods for a lot of cars with that
Old Aug 27, 2014 | 10:01 PM
1997MB's Avatar
1997 C230 (W202)
W202 motor swap
. Did you already attempted the swap because I would like to do the same.
Old Aug 28, 2014 | 01:35 AM
silence's Avatar
sounds like airplane
I think I'm the only person running a 5.0... mine is a hybrid of sorts though with the AMG upper.
It's certainly plug and play though- just not much to gain from the straight 4.3 to 5.0 swap.
Old Aug 28, 2014 | 08:49 AM
Sulaco's Avatar
1999 C43 AMG, 2005 E55 Wagon
Please elaborate.
Did you use the 5.0l non-AMG block and rotating assembly (crank, pistons) but then use AMG heads and cams? What engine did the heads come from?
I'm really curious as to how you did it and what kind of power it's making. A guy local is selling an S500 motor for $400 with very few miles. This is an interesting idea since I have 278k on my 4.3 and would like to yank it out for a complete rebuild and then store it.
Yeah yeah, I'm weird. I'd like to do a swap but keep my original numbers-matching engine, JUST IN CASE an all original C43 is worth something some day
Old Aug 28, 2014 | 11:49 AM
ghiaguy's Avatar
C55 AMG, 300D-T & Karmann Ghia
Definitely worth it!
Sub'd for the impending M113 build..
Old Aug 28, 2014 | 12:38 PM
DRBC43AMG's Avatar
Jeez, thread revival from 2003 Smells a bit mouldy no?
Old Aug 28, 2014 | 07:47 PM
popey24's Avatar
C43 AMG 5.5 - 396.4HP
W208 W210 => plug & Play
W203 W209 W220 => exchange oilpan & oil pump, insert heads water outlet
Old Aug 29, 2014 | 06:17 AM
KJI3jflarryfe93's Avatar
2001 - 2002 facelift w210 E55AMG engines with low compression, do they fit c43 electronics without problems?
or is a 1998 or 1999 E55 engine more suitable for 1998 -1999 cars?
Old Aug 29, 2014 | 07:48 AM
Sulaco's Avatar
I did not know the later model w210 E55's had lower compression. Since it's the later years I would assume they did this for good reason?
Old Aug 29, 2014 | 12:19 PM
cm60k's Avatar
Dennis,
Pre and facelift 5.4l are the same isn't..?,
btw; also need to change the oil pan in W163 ML55..
ZAYED,,
Old Aug 29, 2014 | 12:44 PM
Originally Posted by cm60k
Dennis,
ZAYED,,
hey bro
i believe newer engines had lower comp for better fuel economy
if i put a 5.4litre engine in my c43, doesn't oilpan from this engine clear my front axle or can i use the c43 oilpan instead?
Old Aug 29, 2014 | 06:21 PM
DRBC43AMG's Avatar
I have never heard that lowering the compression decreased consumption. I would think the higher the compression the better burn of combustion, higher power and cleaner emissions.
Old Aug 29, 2014 | 09:42 PM
cm60k's Avatar
hey bro
Depend from which 5.4l model you will go with,,
mostly C43 oil pan can be swappable..
ZAYED,,
Old Aug 30, 2014 | 04:36 AM
last year engine models for w210 e55 had updated engines for better fuel economy, it was not only lower comp, there were some other stuff improved
Old Aug 30, 2014 | 04:38 AM
ZAYED,,
if i find an engine i will definately use the w210 e55 engine from a 2001 or 2002 car.
using my stock c43 oilpan for w210 engine wouldn' be a clearence problem would it?
Old Aug 30, 2014 | 11:15 AM
cm60k's Avatar
Yeah sure, no problem with W210/W208 oil pan clearance..
ZAYED,,
Old Sep 3, 2014 | 05:02 PM
silence's Avatar
I am running the AMG heads on up on what I think is a 2006 m113 5.0 block.
I didn't do the work and I also run a modified HPS Gen 1.
My car is pretty strong... does not always idle well (not a vacuum leak or other easy fix).
