C43 exhaust
You will need to extend the o2 sensors if you do not want a CEL.
I am going to install Kleemann headers, to high flow cats, to Y pipe, to AMG muffler
It will add power AND sound like a BEAST! If you wanted to get cute you could add come electric cutouts and have then dump by the drivers side wheel, that would be LOUD!!
For new Kleemann headers they are around $1800 or so. I was able to get some that were made incorrectly and needed modification for $600. The modification was $400 so I got mine for $1000...
The welds are definitely concerning considering the name Kleemann has in the mod world.
Get a hold of Cory@Kleemann, you might be able to work a deal.
Are there any other companies that make good headers for these cars?, $1800 its way to much, good welding fabricating/CNC shop should be able to replicate these headers for less then a half price, all they will need is a sample.
the idea of pushing cats away from engine is very good idea it reduces instant back pressure, this is done on C36 AMG 95-96 its very efficient (not emission efficient, but power efficient) header exhaust system with H pipe build in. All the cars with OB1 emission system had more power . This was noticed between 95-97 same car same engine, different HP.
There are a couple companies that make headers for the C43 but they are all poop. Kleemann headers are shorty headers and the majority of the other headers are log style. I looked into a company called MKB which makes high end stuff and they do have an exhaust system for the C43 but it is $$$$$$$$$$$$$$$. I think Evosport will make you a set of custom headers but again, $$$$$$$$$$$$$$
Kleemann has the stronghold on the market which is why they can charge $1800.
If it helps the Kleemann headers have been proven to add power (in the 20-40 hp range) so you will gain from installing them but I had a hard time swallowing the $1800 as well so I opted for the ones that needed some modifications. My headers are being swain coated so once everything is said and done I will have a brand new set of swain coated Kleemann headers for $1400, $400 cheaper AND swain coated
