Oil in Water-Help
My 95 C36 with about 160K KMs is getting some oil through to the radiator water. No evidence of exhaust gases in the radiator water and pressure tested cooling system which held 10psi for 4 days, also Pressure tested Auto transmission cooling pipes with no loss of pressure.
Have flushed out as much oil as possible and now running the car again for a while.
There is no evidence of water in the oil.
Car runs great (possibly better than ever). Any advice on what to do/look for would be appreciated.
See picture with younger brother.
Regards,
Bruce
The oil level does not seem to be dropping any more than normal.
1.) blown head gasket
2.) cracked block
3.) Leak in tranny oil cooler (not sure if the C36 has one)
4.) warped or cracked head
All of them are pretty serious
If I had to guess id say an oil passage is seeping into the water jacket around the cylinder due to rotted head gasket. Since the oil system works at a lot higher pressure than the coolant system its getting pushed one way when the car is running. Id start with the head gasket and replace the timing chain guides while I was in there. Ive seen a couple right ups on MBworld of the process. Wish ya the best man..
B
Thanks to all for the advice/comments.
