C43 Front Drilled or Slotted Rotors Please Help
Old Feb 23, 2012 | 08:33 PM
vlad957's Avatar
1998 C43 Amg
Hi I have a 1998 c43 Amg I wanted to get better rotors for the front. People say that drilled rotors are bad becuase they trap heat. Slotted ones are better. Theres a website I wanted to order them from the brand is Sp preformance has anyone ever heard of that company. Heres the link http://www.performance-parts-accesso...1/default.aspx
Old Feb 23, 2012 | 11:03 PM
Outlawlatemodel's Avatar
2006 c230
I hope you clicked your year as the price went way up, I have drilled on front and rear and I am happy, seems like people always post negative about drilled but have never had aset, also those in the link are rears,
Old Feb 23, 2012 | 11:12 PM
LawRens's Avatar
43
Assuming that the build quality is up to spec (oem or equivalent), drilled rotors are fine. They're not so much as "bad," but they certainly have no benefit either; in other words, purely for looks.
There is a claim that drilled rotors weakens the structural integrity of the rotor itself and may eventually cause cracking issues, but there is only a chance that will happen, and only if they have been repeatedly driven hard, such as at track events or road racing with constant hard braking.
Slotted rotors are technically better than drilled performance wise, but none of this really matters if you're just doing daily driving.
Old Feb 24, 2012 | 12:21 AM
importfan21's Avatar
1998 C43, 2017 Honda Accord Sport
This.
Also:
In my opinion, I prefer slotted, as I track my car. However, I realized my OEM front rotors were wearing down quicker than I anticipated, so I was forced to buy drilled OEMs from the 2006 C230K Sport model since I couldn't afford slotted at the time.
If you want slotted and try to buy from R1 Concepts, Brake Performance, or Brake Labs, the front pair runs about $500 for the pair (if you choose the C43 as your car). HOWEVER, I discovered (after buying the drilled) that I could buy a pair of slotted for the 2006 C230K Sport for half the price!
In case you didn't know, the 2006 C230K Sport is the closest-matching non-AMG car in terms of rotor specs (330mm diameter compared to ours 334mm). So regardless of what path you go (drilled or slotted), buy the rotors for the 2006 C230K Sport.
Old Feb 24, 2012 | 12:54 PM
C43AMG's Avatar
Veteran: Army
98 Black C43 , 12’ ML 350 Blutec
Disc Italia's www.brakeworld.com.....then have them cyro treated.
Old Feb 25, 2012 | 06:27 PM
2006 c230
The idea between drilled or slotted is to get rid of the gases, so yes they do work
Old Feb 25, 2012 | 06:29 PM
2006 c230
Originally Posted by importfan21
This.
Also:
I was the first one to source them they work great I have 15k on my mine now with no problem, i have 250 in all 4 drilled rotors,
Old Feb 27, 2012 | 01:16 AM
LawRens's Avatar
43
This statement holds true... For the brake systems twenty plus years ago.
Just google it yourself and you'll find a plethora of information regarding to how drilled rotors no longer have any benefit in today's age.
Old Feb 27, 2012 | 01:51 AM
DRBC43AMG's Avatar
I wonder why some top level manufacturers offer them as standard equipment. Must also have a reason.
Old Feb 27, 2012 | 02:51 AM
2006 c230
hmmm funny how top brake builders still sell drilled, like brembo etc, i am not saying they are the cure all, but i would rather have a set of done right drilled rotors then poorly done slotted,,,,,,
Old Feb 27, 2012 | 04:30 AM
DRBC43AMG's Avatar
Drilled is ample sufficient for street and occasional track (looks nice also). Slotted are recommended over drilled for extensive track use.
Old Feb 27, 2012 | 01:32 PM
Ladies, ladies. We could bicker back and forth all day in regards to what is best. Here it is straight from the horse's mouth; of course we know this already...we just love to debate.
Old Feb 27, 2012 | 05:35 PM
DRBC43AMG's Avatar
+1 for the video. OEM rotors for the C43 are real and totally directional. You must not mix up left and right, and as such has sufficient stopping and cooling power for most situations
Old Feb 27, 2012 | 05:49 PM
LawRens's Avatar
43
Whatever you say
Old Feb 29, 2012 | 09:15 PM
2006 c230
sorry i dont use stop tech stuff,, nothing against them
Old Feb 29, 2012 | 10:03 PM
I didn't post to make a pro-Stoptech stance, but rather for the professional viewpoint on the drilled vs slotted debate.
Old Feb 29, 2012 | 10:38 PM
503C43 ////AMG's Avatar
1999 C43, 2008 P30 E63, 2014 SQ5, 2024 Model Y Performance
I do Stoptech is a GREAT brand
