C36 oil change questions..
Old May 16, 2012 | 12:33 PM
ceez36's Avatar
1995 C36
So I'm going to be doing the first oil change on my new beast myself. How many quarts and what kind of oil do you guys recommend? Car has 139,000 miles.
thanks
oh, and anything else I should know before I get into it other than replacing the oil and filter would be also appreciated.
Old May 16, 2012 | 03:27 PM
nd4spd13's Avatar
1995 C36 AMG, 1998 C43 AMG
8 qts of Mobil 1 0w-40! Only way to do it.
only other thing to recommend is to make sure you have the proper size tool to remove the cap of the oil filter housing. It's the cap at the back right (drivers) of the engine bay, right next to the engine
Old May 16, 2012 | 03:55 PM
ceez36's Avatar
1995 C36
Sweet! Thanks so much for the info.
Old May 16, 2012 | 06:49 PM
ceez36's Avatar
1995 C36
How often do you regularly change it?
Old May 17, 2012 | 04:55 AM
ohlord's Avatar
C36 1995
Was not designed for 0W-40 mobil1 synthetic.
10w40 Conventional oil in your 3.6 liter M104 engine.
Synthetic is for FSS designed engines that have longer change intervals and fleece filters.
No need to be dumping synthetic oil at the shorter change intervals your 1995 engine requires. And no need creating the common leaks that running synthetic oils create in an M104 with 140K miles on it.
Old May 18, 2012 | 05:42 PM
banksboogey's Avatar
95 c36 amg
one more thing
what size was that oil filter housing cap and where would i get a tool like that
and did it have to be torqued back down to 25nm
