driving today and my fan belt got destroyed!!
1999 C43 AMG
i floored it after getting my rear cat delete.
then BAM. hear this repetitive smacking sound. what is it? pop my good and my fan belt is in shredded pieces twirling around.
didnt want to drive the car so had it towed to my buddies shop. what is the cost of replacement? also what ARE these pieces? i found them under neath as well
1999 C43 AMG
Location: Land of mountains, cheese, chocolate and watches
12' W204 C63 AMG coupe "T-Rex", 12' W451 Smart Fortwo Pulse (99' W202 C43 AMG sold)
The wallet looks like it is going to get a slimming diet real fast.
Wonder why the idler pulley broke without any prior warning. Usually they start making noise before doing the nasty break
1999 C43 AMG
mechanic said the pulley seized and got ripped off from the friction of the belt. just ripped right off. shred!
1999 C43 AMG
1999 C43 AMG
or does it only happen on high mileage cars?
1999 C43 AMG
Probably something to check each time you have a service and when starting to wear, get it changed
1999 C43 AMG
Don't sweat around the colar. You cannot overrev the engine. Have you never heard of electronic rev cutoff? That's what saves over reving the engine
1999 C43 AMG
NOOO! The timing chain is inside the block. The rubber serpentine belt drives the accessories on the front of the engine outside.
Guys,, is there a way to pull out the idler screw without moving the radiator.....??
Attachment 237407Attachment 237408
Attachment 237409
ZAYED,,
Attachment 237409
ZAYED,,
La habibi!
I have read that it is possible but a PITTA. Better removing the radiator and while you are in there, check the water pump, remove crank pulley and replace with a lighter one, which gives better response
1999 C43 AMG
is this the same thing that prevented my car from over revving? my nephew shifted the car from d4 to 2nd gear while on the highway!! nothing happened.
Sometimes electronics are more clever than the human brain. No way will the tranny downshift from 4th to 2nd is the speed or corresponding revs are too high, unless you are using a manual transmission in which case you are going to end up with some bent valves
Attachment 237409
ZAYED,,
Attachment 237409
ZAYED,,
