door wood trim piece
My driver's door wood trim piece keeps getting loose and rattling. The first time this happened, it was replaced under warranty. The second time, I took the door panel off and tried to fiddle with the fasteners and ended up breaking a mounting peg off, so I had to buy a new one and replaced it myself. Now, it has loosened again, and the foremost mounting peg has broken off on its own, maybe from rattling around. So basically, it is now attached by 2 of the 3 pegs, so you can imagine how it is just sorta hanging there. It is getting looser everyday as well. I will take the door panel off this weekend and try to tighten up the little fasteners on the remaining pegs to try to tighten it up again, hopefully without breaking more pegs.
Has anyone else had this problem? In the end, ill probably have to pay up for yet another new trim piece.
Cheers
Cheers
i ended up just supergluing what was left of the peg (actually the wider base of the peg) to the back of the seat controller ... when i took the panel off, i noticed that the aforementioned base was about half a millimeter away from the back of the seat control, so i put a bead of superglue there, and it seems to have worked. if it comes off, then ill definitely try your method. (im sure my description is tough to understand, and i didnt take any pictures bc i figured my "fix" wasnt really worth pics and a writeup).
