SUSPENSION COMBO?
I am about to lower my C43 and wanted to know if anyone is running the Vogtland sport springs with Koni adjustables? I don't want a harsh, stiff ride as I want to improve handling, eliminate the huge wheel gap with no rubbing and without sacrificing too much ride quality. I only ask as I previously lowered a C230 Kompressor with the Vogtland/Koni setup and it dropped an inch lower than stated. I don't want to run into the same problem again.
Is it better to go with the Euro springs and Bilstein HD's with 19's or Vogtland and either Koni or Bilstein sports with 18's?
Any pics and advice would be greatly appreciated as well as what pad #'s you are using.
I don't have Konis, I'm dropped on vogtlands with bilstein B8's and 19's. I have #5 pads in the front and #4 in the rear. I believe the Vogtland spring drop claim is based off of the euro spec springs as they are shorter. I am glad I used the largest spring pads possible as I noticed a larger drop than claimed as well. With the largest spring pads I dropped about 1".
The ride is FIRM to say the least but performance is way better than stock.
hope this helps
hope this helps
I am curious as to how the Vogtland/Bilstein HD's ride would be in comparison to the Koni's? Are the Koni's worth double the price over Bilstein's?
Cheers
I was definitely thinking about getting the Konis, as the adjustability would be nice, but as I'm not looking for too much performance for track work, and I'm young so by back is still good, I decided to get the billy sports. Just do the vogtlands again, but don't use #1 spring pads if you don't want it too low.
Also, and make it kind of unclear what your goal is. Stiffer ride = improved handling. And euro springs, HDs and 19s is all looks, and vogtland, billy sports/konis and 18"s (or better yet 17"s) are all about performance.
Cheers
I couldn't tell you about the camber before the kits as I had everything installed at the same time.
I love the Vogtalnd springs as they will not sag like H&R's over time and are not super stiff like the Eibach's. I am definitely sticking with Vogtland without question.
In regards to the Koni's, I left them on the softest setting without ever changing them. I did like the fact that the option was there if need be but at over twice the price of Bilstein's, are they really worth it?
I also understand that the Bilstein sports are recommended over the HD's for lowering springs because of their reduced traveling rate.
Thanks Guys!
