Rebuilding front end suspension(need help)
Old Jul 19, 2012 | 09:12 PM
PJmak's Avatar
The time has come for me to replace pretty much everything that can be replaced down there in the front. I don't wanna take it to the shop because they are all overpriced. I am going to order parts and install them my self but I need some help from you guys...
Im not sure what I should replace. So far I have:
-ball joints
-lower control arm bushings
-rotors(can someone post the exact dimensions of the rotors on our cars)
-engine mounts
-flex disks
-center link
-steering shock
-I also wanna do new spark plugs and wires(should I replace coils as well?)
Can someone please add things to the list. Im not sure what else I should replace.
Also are there any suspension parts down there that are different from non AMG 202s(except for the brakes)
I really appreciate all the input
Old Jul 19, 2012 | 11:52 PM
503C43 ////AMG's Avatar
1999 C43, 2008 P30 E63, 2014 SQ5, 2024 Model Y Performance
Front end suspension:
Control arms (upper and lower)
Drag link (has ball joints and tie rods)
Steering damper
Sway bar bushings
Idler arm bushing
The items listed above are what I replaced when I did my suspension and it made a MAJOR difference.
I believe our front rotors are 334mm
Old Jul 20, 2012 | 12:31 AM
PJmak's Avatar
Why would I have to replace control arms?? Or did you forget to write bushings ?
Old Jul 20, 2012 | 01:15 AM
nd4spd13's Avatar
1995 C36 AMG, 1998 C43 AMG
You're in SoCal, so you shouldn't have a problem, but for anyone wanting to do the suspension refresher with a northern car, this was definitely enough for me to put the actual arms on my long-list of replacement parts to buy
https://mbworld.org/forums/attachmen...pike-strip.jpg
https://mbworld.org/forums/attachmen...my-36-ouch.jpg
Old Jul 20, 2012 | 02:23 AM
DRBC43AMG's Avatar
It can be a DIY activity, but it does certainly need specialist tools (special Klann type spring compressor for example), ball joint splitter, not forgetting you need a full suspension realignment after. You also need to securely lift your vehicle for access. Better giving it to a specialist who has a lift and tools
Old Sep 16, 2012 | 12:23 AM
PJmak's Avatar
Hey guys. I need to order the following parts. Can anyone point me to a cheap website??
-polyurethene bushings
-engine mounts
-rear flex disc
I already have the rest of the parts. Just need to get everything so I can install all at once.
btw I installed magnacore wires and bosch platinum plugs today and wow
Old Sep 16, 2012 | 01:41 AM
DRBC43AMG's Avatar
Good choice
Old Sep 16, 2012 | 12:12 PM
-engine mounts
-rear flex disc
Which bushings are you replacing?
engine mount = http://www.autohausaz.com/ or http://www.bmaparts.com/ (BMA autoparts can get you stuff not listed on the site as well. I had them order a lemforder tranny mount that was not listed, email them)
Rear flex disc = http://www.autohausaz.com/
Old Sep 17, 2012 | 12:03 AM
PJmak's Avatar
I need LCA bushings and I want polyurethane ones.
I just ordered the flex disc and motor mounts from autohauz
Old Sep 17, 2012 | 07:00 PM
904C43's Avatar
1999 C43
My other thread let me know that I did not need LCa bushings becuase of my front kmac kit. Does anyone know what the mbarts rear camber arms rePlace? Is there something on the list above that I don't need?
Old Sep 18, 2012 | 05:36 AM
KJI3jflarryfe93's Avatar
if you buy MB Arts camber arms, you replace this arm from your rear axle with the adjustable camber arm instead.
http://www.autohausaz.com/search/ima...2103503406.jpg
adj camb arms seems to be a good investment for your rear tires.
I'm still happy with mines, but I don't know for how long I will be happy?
If and when they start squeeking, Houston we have a problem.......................
