Activated Charcoal Filter
Old 04-09-2013, 01:49 PM
  #51
speedyc43's Avatar
1999 MB C43 2004 E55 AMG, 2004 Suzuki GSXR, gl63
It's located in the driver side rear fender under earth the inner fender beside attached to the charcoal canister it has on hose and one electrical connection.
Old 04-09-2013, 02:11 PM
  #52
speed43's Avatar
c43
Originally Posted by JohnnyRock
Speed, how did you determine it was the purge valve? Thanks for posting your findings, it should save a guy like me potential big $$$ on a new charcoal canister and/or filter!
Zayed, thanks for posting those pics and part #'s!
A friend tested it by putting 12v current to it.
When this is done you will hear it make a sound. Mine made no noise at all. The used one i bought made the sound which is pretty much closing or opening the valve.
It use to take me 15-20 minutes to put in 10.00 of gas.
Now I put in 20.00 in less than 50 seconds.
Old 04-09-2013, 02:33 PM
  #53
JohnnyRock's Avatar
1998 C43 AMG
Thank you speedyC43 and speed!
Old 04-09-2013, 05:17 PM
  #54
cm60k's Avatar
00 C200 & 00 C55 & 06 SLK55
Thanks again, Zayed. First thing I'm going to try is replacing the purge valve. Autohaus says this is the right part.
Welcome....
ZAYED,,
Old 04-09-2013, 05:19 PM
  #55
cm60k's Avatar
This is the place of the "shut-off valve".....
ZAYED,,
Old 04-09-2013, 05:29 PM
  #56
cm60k's Avatar
I hate sounding like a newb, but where is the purge valve located with regards to the abs unit?
If you look down-side of the ABS/ESP pump, you will see it connected to Electric wire & "2" vent hoses....
ZAYED,,
Old 02-20-2017, 11:34 PM
  #57
W202AMG's Avatar
W202 C43 1999
What sort of effect will any of these items have on cold start?
Quick Reply: Activated Charcoal Filter
