Need Advise/Help
When I press and hold the remote key to lock or unlock to bring all windows down or up. It won't work, it will unlock the doors but not lower the windows?
I just installed a brand new battery and still won't work.
Yesterday the drivers window and passenger side window won't work up or down. I have to remove the negative cable from the battery for 20 seconds and that makes both windows work for a couple of days than they stop working again.
I had this problem before with just the passenger side window not working but now both front windows are doing this?
Why does taking off the battery cable make them work??
I replaced all fuses and relays with Oem parts and still have this issue.
Any help is greatly appreciated.
But what I want to know is WHY does the front windows always start to work after a reset of the battery? Than after a day or two they stop working. Than do the reset and they work than after a day or two they stop working, know what I mean?
This problem is making me want to get rid of the car. Electrical problems I do NOT know how to fix. Anything else I can do myself, this is so annoying...
ZAYED,,
Today both of my remotes would not unlock or lock the doors. Batteries on the remote are brand new. So I disconnected the battery for 20 seconds and the car started to read the remotes and both remotes now opens and closes the doors. What is going on?..
Attachment 248487
ZAYED,,
Attachment 248487
ZAYED,,
Do we have one for SURE on our c43's?
It depends of the spec. & model of the car,,
You may had "2" Relays,
One for the (Comfort Relay), #: "001 542 78 19", and the other one for ta (Window & Seat) adjustment #: "002 542 22 19" ,
You have to check how many Relays you have in the Trunk (under the carpet).....
http://blogs.yahoo.co.jp/moony_murmur/133582.html
https://mbworld.org/forums/c36-amg-c...eal-quick.html
ZAYED,,
Btw, a Mercedes mechanic told me that I HAVE to get the module that I had replaced on the door itself reprogrammed. He said that is why it works for a while after I disconnect the battery. After a while the computer miss reads it and shuts down.... Can that be the reason too?
I prefer to replacing the "2" Relays in the same time, and spray a contact cleaner to the circuit & brush it with a soft brush, it may help either....
ZAYED,,
