My C43 need shocks: Where to get them?
I would like to know if any of you know few sources to get quotes/shcoks for our C43's. I would like to stick with Bisltein Sport or Koni yellow.
Seems to me pretty hard to find these shocks for the C43 AMG, but are more common to list them for the 230K or regular W202 chasis, not even the C36 AMG.
I do remember some time ago searching for Koni shocks and found a thread that someone linked a shop that sell some stuff for our C43, then i emailed the guy and said he had special valved Koni for our C43's but I can't find that thread, nor the email he wrote me.
My C43 is a euro version, so it's already lowered comapred tot he US specs C43.
The only websites I found some info (not the info I wanted to read) are:
http://www.eshocks.com/bil_Ind.asp?V...ubChar=Q#thumb
http://www.shox.com/appguide/shoxsho...ctsdisplay.php
And that's it. I sent email for oth parties and I'm still waiting a reply. Shox seems to sell a Koni "suspension kit", but I'm afraid that this kit does contain Koni springs which I'm not interested since I have already the lowered OEM springs and even if the rate is different, I don't want to change that, specially for the price.
Any other sources that any of you could led me know, I woudl really appreciate it.
Decisions decision...
I started to search for these and found this site the cheapest and got this message from the guy at the shop, so I would order those anyways:
8041-1315sport 2-3 weeks backorder
8041-1316sport 2-4 weeks minimum special order
http://www.ajusa.com/KONI-Sport-Shoc...1f14q6413.html
Koni reference
http://www.koni.com/car-racing/finder/
Thoughts?
what kind of ride can you get with lowering springs?
perhaps famous MB cabin ride will transform into a stiff rattle box?
I might also be interested in getting Koni's when I have Vogtlands on my ride.
Koni's or genuine AMG/Bilstein shocks?
A/B shocks will cost more, no doubt.
there are good deals on Koni's on german webshops, less good deals from stealership for OEM shox.
My C43 AMG is a euro version so it's lowered already. The car was bought with SACHS Contour (or something among those lines) black shock almost new for the front (I think these are the normal shock for the 280, etc) which were in perfect shape and for the rear still the black OEM MB Bisltein that were in good shape from what i could test them by hand.
Problem is that my MB sucks BIG TIME the suspension, the car doesn't absorb the unevean crappy roads here, feels loose on the front and doesn't work as many other cars I have tested, feels "boatly" and when you push(balance) the front down to the ground it's pretty easy to "compress" the front of the car.
I always read in the reviews by mags and owners that the stock factory "new C43 AMG" was stiff and harsh in the suspension field, something that I cannot understand/agree with my personal experience, of corse might be due the mixed shocks I have?
Koni reference
Thoughts?
And yeah, if your front shocks are designed for a C280 then the added weight of the V8 and other features of the AMG will make them softer than needed.
Somewhere I read that C36 AMG are actually tad heavier car than C43 because of the engine? Don't know....anyways I don't think there is a huge problem by a small difference in weight between the C36 and C43 powerplants to affect the behavior of these shocks?
So the bushing of the Koni shocks are not good? Do they wear out quick?
What Konis are your using in yours? (P/N).
you are using non approved shox on your car, giving you a bad ride.
so Koni besides Billy Sport are the only shox available for decent price?
I might try Koni's when the day comes.
I hope I don't wear out my factory shox fast when I have my Vogtlands installed?
where are you located if you have a euro version C43?
your car does it have full options from factory?
parktronics/rear blind/folding mirrors/factory alarm?
these options are giving the european c43 a fatty ride, slowing down the car.
US sold C43's must be faster?
Yep that's correct, C36 is heavier than the 43. There won't be using the Konis valved for the 36, but using say a Bilstien shock that's valved for the lighter non-AMG version on an AMG won't be great.
No. The bushing of the Bilstein is bad, the Konis are solid, and good
KO-8041-1316Sport in back, KO-8041 1315SPORT in front.
for how many years did you use your Koni's?
do you always drive on softest setting?
is there a huge difference between soft - normal - stiff settings?
do you get lots of cabin rattle on full stiff setting?
bouncy ride on bad tarmac?
car has more stability around corners and less body roll when braking hard with Koni's?
straight forward driving stability is it good when windy outside?
if using stiff settings freequently might wear out shox faster and cause other suspension parts on C43 to wear out fast?
is it possible this would happen?
I'm seriously interested in Koni chicken jelo shox.
they must be long lasting without problems from valve adjustments.
Are Koni's known to give any problems from rubber bushings or valve leaks?
Their plastic adjusting hat is it a good quality part that won't break or the threads beneath the hat gets worn out if doing test adjsutment several times?
is it a good description?
kowalski, Koni twin tube adjustable shocks are adjustable in REBOUND but not compression stage, so it's not exactly like you might be imagining that would result in a lot stiffer suspension in full stiff position for daily use when you hit pot holes, bum stops etc when actually the shock/suspension compress and you might expect and "hit & jump" of the car because is stiff (I'm exagerating here to get the idea) but it will reduce the rebound effect so if you are for example at high speed on a unevean(sp?) road this will help to keep the car on the ground and not lunch off the ground for say the least lol... actually making it in the stiffer posotion, the overall behavior of the suspension get kinda stiffer/tighter feeling...I know this last sentence might sound contradictory but that's the way I feel/see this setup when I had it in my BMW e30 turbo.
-Diego
Only other shocks I'd put on would be from the KW kit
Thanks!
-Diego
overall review about yellow adjustable Koni.
this is a great shock for our C43's?
anyone used or know about Koni FSD shox?
are FSD Grand Touring shox suitable for C43?
is there a huge difference between yellow adjustable vs FSD?
which one would be an ideal purchase?
I know FSD is a new designed shock vs the yellow ones, any adjustable settings on these FSD?
