1997 c36 without an ovp relay?
Old Feb 16, 2013 | 07:42 PM
Teh Pope's Avatar
1997 C36 AMG
So after doing an extensive search on this and other forums on the symptoms my c36 was having I concluded that it needed an ovp relay. So i went ahead and ordered said part from autohaus az (great site and quick shipping), got the part, popped the hood, removed the cover on the passenger side and...no ovp relay to be found. I then searched the other fuse boxes on the drivers side and in the trunk and nothing.
recent repairs; head gasket, valves, head sent to machine shop, harmonic balancer, spark plugs, coils, serpentine belt and belt tensioner, and air pump fuse. btw, when i changed the air pump fuse, it ran way better but still idles rough at times.
On cold starts, the engine starts just fine and idles fine. then it gets a bit rough as it warms up. On warm starts, the battery light comes on. I blip the throttle and the light turns off. Any Ideas? I put so much faith on it being the ovp that now that there is no relay to be found, im at a loss. Thanks!
Old Feb 17, 2013 | 01:44 AM
dearlove's Avatar
190e & c36
whats actually wrong with the car? just idle?
Old Feb 17, 2013 | 10:48 PM
Teh Pope's Avatar
1997 C36 AMG
rough idle when it warms up and on warm starts it hesitates a little and when it does turn over, the battery light comes on and goes away after i blip the throttle.
Old Feb 28, 2013 | 12:29 AM
jarvis210's Avatar
1998 C43 w/ N/A 5.4l swap
On your 1997 it has a k49 relay module instead of the over voltage protection relay. It is located by the diagnostic connector under the hood. You can identify it because there are like4 15 amp fuses in it
