slk 55 brake upgrade on c43
The install was pretty straight forward cut the backing plate, drill the hub to accept the newer larger bolt to hold rotor on, also i cut the sway bar mounting off and shortened sway bar to allow for clearance of the caliper to the sway bar. everything went ver smoothly and came out looking very nice.
sorry about the pictures click on the top and you can see them
http://www.flickr.com/photos/89955009@N04/8572395185/
http://www.flickr.com/photos/89955009@N04/8572396507/
http://www.flickr.com/photos/89955009@N04/8573489798/
http://www.flickr.com/photos/89955009@N04/8572414369/
next project will be a limited slip diff project
I don't think I will ever do this mod unless I turn my C43 into a track car, none the less I LOVE the look of the caliper
Do you relocate the mount of the sway bar bracket...?, it should be, to give you more clearance when you L/F turning,
and cut the sway bar end about 25mm,
see this value link from our friend "Money-one":- https://mbworld.org/forums/c36-amg-c...small-car.html
ZAYED,,
ZAYED,,
of course depends of your Rims off-set style,, or you can use the 5mm spacer with Rim hub sitter:-
http://www.ebay.com/itm/H-R-5mm-DR-Wheel-Spacer-5x112-66-5-12x1-5-Mercedes-Benz-300SL-500SL-1990-1996-/330733798498?pt=Motors_Car_Truck_Parts_Accessories&hash=item4d01454462&vxp=mtr
http://www.ebay.com/itm/WHEEL-SPACERS-MERCEDES-BENZ-10mm-MADE-GERMANY-/270759655907?_trksid=p2045573.m2042&_trkparms=aid%3D111000%26algo%3DREC.CURRENT%26ao%3D1%26asc%3D27%26meid%3D6477066492405341896%26pid%3D100033%26prg%3D1011%26rk%3D1%26sd%3D270759655907%26
ZAYED,,
1) Engine swapped from 4.3L to 5.4L, with-out change the ECU, and with-out any kind of ECU tune,,
2) Installed Kleemann Cams,,
3) Installed Kleemann Headers,,
4) Installed "Evo-sport" UD pulleys,,
5) Replaced the Injectors from stock (217cc) to (283cc) from "C55/CLK55/SLK55",,
6) Replaced the Ignition Wires from stock "Bosch" to "Magecor KV85 ",,
7) Switched the tranny from "722.631 A580Nm", to the one from (S/SL600/65 Bi-Turbo),, which is "722.649 A900Nm"
8) SLK55 Engine Oil Cooler
9) Power Steering Oil Cooler
ZAYED,,
