C43 starts then stops
Iv recently (last week)replaced the MAS,Crank sensor and Cam sensor because the crank sensor failed on me big time..this doesn't appear to be the symptoms of the cam or cranks sensor...
Maybe a bad contact in a relay somewhere?.
I need star for home use!.
Any suggestions?
don't know could be other problems?
a few years ago i heard about flywheel problems, it needed som greasing because of starter issues.
it's been a few years now and i forgot about all the details causing the problems!?
My money is on a fuel issue. Think about it, 3rd try it works....enough fuel in the cylinders to start by then...
did you check the fuel pump or fuel relay....??
is the PCV hoses doesn't has any leaks....???
ZAYED,,
I think I will purchase a scanner of sorts, does anyone know of a good star copy which is capable of doing everything the genuine does?
Fuel filter- According to the MB services the fuel filter has been changed twice since new,would they really clog this quick? fuel is pretty good here..I would think this would effect overall performance not just startup?.
Fuel pump - It appears to be working ,ie I can hear it fire up every time i turn the key.
Also If it was the pump would the engine miss or run rough on startup if fuel pressure was low?.
Crank,Cam and MAF sensors - Are all genuine bosch ones,and yes fitted myself last month and I dont recall checking the WIS when I did this!,I guess the usual method is to plug into star and check the waveform produced by the sensors and reset for the MAF?.
All PVC hoses have been recently replaced,including the gaskets around the MAF, I will recheck these incase I have not connected something properly!.
that’s mostly can cause some kind of interrupting to the fuel delivery system,
i think its better if a fuel regulator comes in separately in the fuel rail.....
ZAYED,,
There is already a problem with the sensitivety of the receiver ie I need to be very close to the car to unlock/lock etc ,with the new or original key.
ZAYED,,
The symtom I have is either the engine goes to crank but stops abruptly within .5 seconds,or starts but as soon as it fires up drops dead ..its nice and smooth like turning the key on then straight away off as soon as it fires up...so alot quicker than 5 seconds.
