Is it possible to install camber kit on c43 your self???
Which camber kits are you talking about as you mention front and rear? The front can only be adjusted using special OEM eccentric bolts but with very limited adjustablity. Rears are not adjustable at all.
If you have a KMac kit for front and rear using the adjustable bushes, the installation can be DIY if you have the right tools and equipement as you need to extract the old bushes from the front A arm. That needs doing with a hydraulic press as it will most likely be rusted. Other option would be to buy a new A arm, press out the bush and insert the KMac adjustable. Rears is the same problem i.e. extraction/insertion of concentric bushes.
If you have adjustable camber arms like those from Speedybenz or other types available around here, it's a simple swap using regular tools. Just make sure to have some rust penetrator for the nuts and bolts.
In all cases, you will need specialist equipment to do a full suspension alignment after the modifications.
Keep us posted
P.S. I will probably do a full suspension rebuild on "T Rex" next winter to install the KMac kit for front and rear I have and change all the rear suspension arms which I already have in a box. I'll probably also get new front suspension A arms too. That should give a second life to "T Rex's" legs and go well with the KW suspension kit already installed
Thanks,
(currently putting the roll bar into our C43 hill climb car......)
Posted from Mbworld.org App for Android
