Buying new spring pads tomorrow
Old May 15, 2013 | 05:11 PM
KJI3jflarryfe93's Avatar
I just wanna be sure as I might get new Koni shox for my car soon.
Should I buy 5 front/4 rear spring pad combo to avoid rubbing issues?
Koni's will be used with Vogtland lowering springs.
My car has ET35 rims front and rear if it matters for rubbing issues?
I'm looking for 1 to 1½ finger wheelarch stance, factory gap now gives me a 2 finger gap on front and rear which is a bit high for me.
Is this the best recomendation using 5/4 pad combo?
Old May 15, 2013 | 05:45 PM
FrenchBenz's Avatar
1999 MB C43 AMG
Yes and it's the thicker you can go I believe. The dealer did not have bigger when I bought mine if I recall correctly.
Old May 15, 2013 | 09:02 PM
503C43 ////AMG's Avatar
1999 C43, 2008 P30 E63, 2014 SQ5, 2024 Model Y Performance
ET 35 might rub in the front, how wide are they?
Old May 16, 2013 | 02:19 AM
front they are 8.5 wide brabus rims
rear is 9.5 wide.
with 2 finger gap front and rear, there's no rubbing now.
will it rub with thicker #5 pads in front?
Old May 16, 2013 | 09:21 AM
rear is 9.5 wide.
Nope you should be fine
Old May 16, 2013 | 03:04 PM
greit thanx.
I just ordered them today from the stealership.
will cost me approx $50 dollars for 4 rubbers with discount.
only thing left to buy are my Koni's chikkan yello shox
I hope these are good to my taste and do my car well in performance and longlife?!
Old May 16, 2013 | 10:59 PM
greit thanx.
The north american site has them listed as:
Fronts = $292.80 per pair
Rear = $285.60 per pair
How much are you paying for them?
Old May 17, 2013 | 12:49 AM
mine will cost €240 euros front and €228 euros for rear
total €468 + €27 shipping
Old May 17, 2013 | 02:38 AM
Super B's Avatar
'97 c36
Hey while we are talking about pads.. Is there any difference between the set up for the 43 and the 36? I just ordered some vogtland springs also and was planning on running the #4 and #5 pad set us as well. Is this correct?
Old May 17, 2013 | 01:46 PM
that's what the experts say, use #5 front and #4 rear
got mine today, they are waaaaaay to thick
what kind of wheel gap do i get with 5/4 combo + Vogtland 35mm + Koni yellows?
1 finger - 1½ finger - 2 finger?
my stock factory wheelgap is now 2 finger.
I don't want to have the same 2 finger space with Vogtland install!!
has to be a perfect 1½ finger gap
When using 5/4 pads including all my new suspension parts, am I going to get more suspension instabillity from my pads coz they are way too thick?
Old May 17, 2013 | 02:13 PM
nd4spd13's Avatar
1995 C36 AMG, 1998 C43 AMG
Yes there is a big difference. C36 uses W201 style pads, where the spring is essentially "cut" so the spring pad has a gradual indent in it for the top coil of the spring to go into. C43 uses W210 style pads, where the spring is gradually tapered down at the top so it is flat, so the spring pad is more flat, and therefore much thinner. Luckily (for me) the tops of the pads are identical. So I am running C36 Vogtland springs and #1 and #3 W201 style pads in my C43. The MM thicknesses and corresponding pad # is different for the 201 and 210 styles, and I don't think there even is a #5 in 201. I think a while back Saab posted both styles and their mm thicknesses.
Old May 17, 2013 | 05:32 PM
Super B's Avatar
'97 c36
Hey thanks buddy good info. That's good to know. For sure w201 pads I remember turning the pad and locking them onto the spring when installing them after the front end rebuild. Hmm guess ill just have to wait to see how these springs are cut before ordering pads. From the picture they look flat like the 210 style even though they are listed as c36 springs. Ill do a search and see if I can come up with saabs post. Since this is my daily driver I'm leaning torwards the thickest pad I can get. (Which may already be in the car since I have a 4 finger gap... Hell I can almost fist the old girl.. she's dirty like that.. need to wash her wheel wells before sticking my head in there and working it but that's besides the point. )
Guess wait and see what shows up.. Currently Savin coin for koni's thanks again for the heads up.
Old May 17, 2013 | 06:32 PM
nd4spd13's Avatar
If you're getting the springs from Vogtland US listed for C36, they'll use the W201 style pad.
Old May 17, 2013 | 10:48 PM
don't worry, you will be low. I have less than 2 finger in the front and close to 2 finger in the rear. Raked look for sure, unless you want the SLAMMED look you will be glad you didn't get smaller pads
Old May 18, 2013 | 04:13 AM
jason, i don't want the slammed looks, i leave that stance to the younger people.
if i get the raked look that will be great
do you have any rub issues when loading your trunk + people in the backseat?
I can do a test with my old stock #1 pads when doing this modification if i get any rubbing issues.
I checked my stuff at home.
This is what I have:
2x Front #1 pads
2x Front #5 pads
2x Rear #1 pads
2x Rear #2 pads
2x Rear #4 pads
Old May 18, 2013 | 12:49 PM
2x Front #1 pads
2x Front #5 pads
2x Rear #1 pads
2x Rear #2 pads
2x Rear #4 pads
I have never had any rubbing issues. I have had 4 full grown men in the car (2 in front and 2 in rear) without any tire rubbing. With the #5 and #4 pads you can still see the top of the tire (not tucked into the wheel well) but it is close in the front, not as close in the rear.
Old May 18, 2013 | 01:26 PM
Super B's Avatar
'97 c36
Hey Jason is your total out side diameter bigger than stock? Or are your sidewalks pretty thin? With the kmacs and those 19's how is it on road noise?
Old May 18, 2013 | 03:34 PM
Rolling diameter needs to stay within 2% I believe to keep the traction control in check as well as have an accurate reading on your speedometer. To do this as the rims get bigger the profile gets thinner. I am running 235/35/19 in the front and 265/30/19 in the rear, very little sidewall. Helps when cornering as there is basically no sidewall flex but they also tramline frequently
Road noise is pretty much non existent but I think road noise has more to do with your tire design than sizes. Mercedes is pretty good about keeping outside noises outside as well. When I had my 1999 Accord the difference was night and day, the C43 was SOOOOOO much quieter.
I will say this, if I had to do it all over again I would get 18's. 19's look cool but I think the extra profile on 18's would give a little smoother ride.
Old May 18, 2013 | 04:09 PM
Hey J.
I was browsing your profile pictures of your sweet ride.
I don't see any pics after you lowered your car.
I only saw a black MB C-class jeep.
I appreciate if you want to take some cool poses of your ride for me?
Front wheel gap, rear wheel gap, and finally some full car pictures.
Make sure you take good pictures where I can see the gap between wheel arches and tires.
You show me yours, I show you mine when I'm done modified.
Müchas gracias amigo
Old May 18, 2013 | 05:17 PM
Hey J.
Look at my sig pic, it was taken after I lowered it
Old May 18, 2013 | 06:33 PM
yes I see that but you're standing up and the pic doesn't show the wheel gap very well.
you have to kneel down to get in perfect position for good close up pictures
Old May 18, 2013 | 07:38 PM
Super B's Avatar
'97 c36
Well with the noise I was more wondering with the kmacs. They are poly right? I ran into that when I had my firebird with full suspension on poly bushings the road noise was night and day worse over the stock rubber. But sounds like its not that bad on the 202. I'm just concerned about the vogtlands being too low. But your running 19's and seem to be happy. Nd4spd seems happy soo maybe I'm worrying about nothing.. in the last year and 6 months she has logged over 32k so road maners are right there with performance. : / I'm hoping the thickest pad will be enough just have to see. I'd be perfectly happy with 2 finger gap. I'm wondering if I should have gone euro route.
Old May 18, 2013 | 11:17 PM
K-MACS are poly but I didn't notice a difference over stock. I think you could get away with using the OEM eccentrics instead of the K-MAC's. Euro springs would be a tad higher than Vogtland. That being said I am high enough that I don't bottom out on anything.
Old May 18, 2013 | 11:46 PM
Saaboteur's Avatar
eclectic assortment of cars
The KMacs squeak, in my experience. If I were to do it again, I wouldn't I think.
Old May 19, 2013 | 11:36 PM
Super B's Avatar
'97 c36
You know nd4spd mentioned that too. I think I'm going to give it a shot and see what the alignment shop says. If its too far out can always go to plan B. im thinking im just going to buy a used set of lca's so if i have to go the k-mac route i won't have to distroy the solid 203 bushings i pushed in last spring.
As far as the sqeaking Saab I'm sure you already know this but there is a specific synthetic grease just for those poly suspension bushings. The Spohn bushings on the firebird were horribly squeaky before greasing them. I forget the name of the grease but I can look it up if your interested.
