Wide body conversion
There is not so much to add, because C43 side skirt is a little wider at the bottom and smaller to the top. so it is more or less only top part to be modified.
There is a styrofoam I added on, then plastic putty with metal net. On top I will put Diolen (plastic) fibre with resin soon.
Later on all you can do is continuosly run around the car and watch. I think it is pretty even. But also it wouldn't really matter because you won't se both sides at same time...
http://i1122.photobucket.com/albums/...y/DSC00448.jpg
http://i1122.photobucket.com/albums/...y/DSC00449.jpg
http://i1122.photobucket.com/albums/...y/DSC00450.jpg
Perhaps needs a good wash before the paint....
