Wide body conversion
I am curious to see it in sun light when the red/gold effect is visible...
With those W204 style mirrors you Need to pay attention... there is the Frame fixed with 4 screws to the mirror Body. But on Drivers side, the 2 outside screws prevent the mirror from showing the road, you can't move far enough out. You Need to remove the 2 screws and cut the case where screws are linked and glue the Frame to the mirrors body.
but looks astounding nonetheless. Would love some info on that diffuser. did you make that?
Now some six pot Brembo brakes and BBS wheels would make a perfect finish
http://s1122.photobucket.com/user/Po...28942217281701
I wonder if BBS can offer those dimensions (11x18)
And I always wondered about the iron sheet they fixed on the border of the Fenders and then fixed the new Fenders to that iron sheet.
But I never found that iron sheet removed later, what ment that the wheel can not fit under the Fenders without touching that iron sheet.
So I needed to find my own solution starting completely different from the russion Project.
