*sigh* post tune up problems...
So I'm all excited to get him back on the road, I take him for a drive, and he's stumbling/stuttering a but when getting on the gas. He's sluggish below ~4500 rpm, then picks up a bit, but not like before I changed everything out.
I had the battery disconnected for a while when repairing some battery acid rust in the spare tire area, and the car had to re-learn all the sunroof/window positions, etc.
Is it likely that it's the plugs/wires? It doesn't feel like it's missing, but then again I don't know if it's easy to tell if these engines are missing or not. Could it be the crank position sensor?
The plugs I used are the FR8DPP33+ that AutohausAZ had listed as the OEM plug. The wires were genuine Bosch wires, all correctly labeled for position, etc.
Does the fuel pump usually make a hissing if you're standing behind the car?
I'm worried it's the plugs or something else I did, so any thoughts/input welcome, where do I start? Anyone else experienced this after a tune up?
Edit: just found this post about the CPS (http://www.benzworld.org/forums/w163...-sensor-2.html), is it really possible that the CPS can cause so many problems? Could it be causing the hesitation in the engine?
Do you guys recommend a good code reader? I have one of those cheap bluetooth ones for an app on my phone, but it apparently doesn't read as good as it should/could. My indie found 4 pages of old, stored faults when I had them look at the car the very first time, and cleared them. Car was fine until I touched it, haha.
nd4spd, ok, thanks. not seeing a CEL, but may try to pull codes just in case.
one other thought/question, I had wd40 in the plug tubes to try and ease the new plugs back in (rusted), could the wd40 have borked my O2 sensors?? I've been reading that bad sensors can cause this as well, and there was a ton of smoke when I first started him up after changing everything out.
It's an internal combustion engine, you'll know if it's missing. It would also be turning on your check engine light and the engine management would completely shut down that cylinder until the next key cycle.
No CE light, it's not missing, just poor performance. I'm starting to lean towards the MAF or oxygen sensors, just not sure which to start with first, or do both, replace one piece at a time and see what fixes it I guess.
You would know if a cylinder was shut down from missing, you would throw a CEL and your AMG would sound like a Subaru.
Both MAF and o2 sensor issues would throw a CEL as well
Main work done was the fuel filter/plugs/wires/VC gaskets (complete with sensor safe gasket material). I don't have the old plugs/wires anymore, tossed'em already. I do have the old fuel filter I could try swapping out I guess, but the replacement was MANN and I'm 100% sure I got it back on the way the old one was set up.
It starts fine, runs smooth, no CEL, drives fine if you're not stoping the pedal, but as soon as I stomp the pedal, it's slow/sluggish below 4500rpm, and then it improves a bit from there.
I have seen maf problems before without a check engine light, you can go in with a tester and check your fuel mixture adaptations and see if they are drifting from where they should be. However usually when you have these problems, the car is ok under lower rpm and load, but falls on it's face on the higher end.
It really just needs a real diagnosis. But I would check everything you did and also for any vacuum leaks and also un-metered air leaks. I've seen many air leaks before that you can't hear, you can have an air leak that doesn't make any noticeable noise.
You can kinda only install it one way due to the 3 normal sized lines and the smaller breather/return/whatever line. I did one line at a time to ensure that I got them all on the right ways.
DRB/Johnny, yeah, I'll see what the shop says, I'm super curious too since it was running fine before I swapped stuff out.
