C43 w202 Vogtland springs
Old Oct 4, 2013 | 01:53 PM
ni7robles's Avatar
1999 C43 AMG
Good day to you all! I joined mbworld recently. I ordered the vogtland springs for my 99 c43 today. I am pretty sure I have to also purchase different spring pads to make the springs fit. Is that true and if so what size should they be? Or can I just run the vogtland springs with the stock shocks and pads? Thanks I appreciate the help!.
Old Oct 4, 2013 | 02:24 PM
KJI3jflarryfe93's Avatar
stock shox and Voggie springs is a no good combo.
you need shorter sport shox
koni yello or billy b8's for you, i run koni's and love em
vogtland springs for C43 AMG #952079
i run #1 pads front and #4 pads rear = gives 0.75 -1 finger gap on wheelarches = seksi look
you should invest in adjustable camber arms for proper tirewear, maybe doing a full suspension overhaul like i did just to get full synergy with the rest.
now i get this tight gocart feel when i drive my car.
Old Oct 4, 2013 | 02:38 PM
ni7robles's Avatar
1999 C43 AMG
That pretty much sums everything I need to know. Lol ill look into the shox and pads. Is there a specific part number for the pads? Or measurement? Im planning on doing everything myself even if it takes a couple days.
Old Oct 4, 2013 | 03:24 PM
here Yugo with all spring pad sizes
others will give you their likings and dislikings regarding different spring pad sizes.
on my car 1/4 combo fits well on ET35 rims
https://mbworld.org/forums/c36-amg-c...pad-parts.html
Old Oct 4, 2013 | 03:58 PM
ni7robles's Avatar
1999 C43 AMG
Okay ill give it a shot. Thanks for your help. Ill post pics of when its all done soon.
Old Oct 4, 2013 | 04:19 PM
this is what I got with my new suspension overhaul
Old Mar 16, 2021 | 11:13 PM
uva81uy's Avatar
W202 & R129
Today
I put h&r sport with Bilstein sport. Nbr 1 shim pad at the front and nbr 2 back.
Not happy with the look. Too low on the back. What do you think ?
Old Mar 17, 2021 | 12:29 PM
MattCordell's Avatar
C43 AMG with a tune up
It's definitely to low in the rear
Try #3 or #4 in the rear.
H&R springs are low cuts and very harsh, you might not like the feel of your car?
Old Mar 17, 2021 | 12:32 PM
uva81uy's Avatar
W202 & R129
I just bought the nbr 4 pads for the rear and the adjustable rear arms suspenson because the car now has negative camber.
Hope this wld fix the problem.
Car feel harder, obviusly with the prevois config was smooth, but i like the low look, i expect some improvement on the rear with the arm and the shim pads.
Old Mar 17, 2021 | 03:46 PM
It's always a trial and error when it comes to suspension ride height adjustment.
Looks like you have a European W202, your front bumper has sensors for parallel parking, you have it in the rear too?
This is a nice feature which many cars don't have.
It's a nice option, it comes very handy for narrow parking
Old Mar 17, 2021 | 03:54 PM
uva81uy's Avatar
W202 & R129
thanks, is from candian mkt and yes, the parktronik is OEM. 2 screens for the front and 1 for the rear (in the tail brake light)
Old Mar 17, 2021 | 04:22 PM
Old Mar 17, 2021 | 04:28 PM
uva81uy's Avatar
W202 & R129
jajaja, im looking replacement for the center display, it has rust and trying to clean it i broke it up
Old Mar 17, 2021 | 04:32 PM
Do you mean the small center display screen on top of the dashboard for parking sensors?
What do you mean it has rust and it broke down on you?
Displays can go bad and fade.
Old Mar 17, 2021 | 04:37 PM
uva81uy's Avatar
W202 & R129
yes, that one. I tried to clean it and disambling the thing I broke the plastic cover. It was bad because of the sun effect and years.
Old Mar 17, 2021 | 04:48 PM
Did you go to dealership?
Do they still sell this part?
If not, junkyards is your best friend.
When you removed the center display, did you pull it right up and it came off?
Plastic housing is broken or the display is busted and non visible?
