"Voltphreaks" batteries
Old Oct 10, 2013 | 06:09 AM
cm60k's Avatar
Guys,
Anyone try a lightweight battery from "Voltphreaks", they got a good reputation on their batteries.....
http://www.voltphreaks.com/products_street.php
BMW’s & Porsche’s guys went with it & love it:-
http://forums.rennlist.com/rennforum...-r-owners.html
http://www.m3post.com/forums/showthread.php?t=787176
ZAYED,,
Old Oct 12, 2013 | 09:20 PM
JohnnyRock's Avatar
1998 C43 AMG
Zayed, $1200 bucks for a battery?!?! Are you crazy?!?!
Old Oct 12, 2013 | 10:45 PM
cm60k's Avatar
....., agreeed,
its a damn hell expensive....,
just need to see who went with them.....
ZAYED,,
Old Oct 13, 2013 | 01:20 AM
KJI3jflarryfe93's Avatar
what's so special about Voltphreaks?
are they better than Optima yellow?
Old Oct 13, 2013 | 02:59 AM
raymond g-'s Avatar
99 E320
not really worth it unless you're really counting ounces and trimming weight for
race related purposes etc. for 2 wheelers, the weight savings can really pay
off in terms of power/weight ratio (less so for cars).
i have similar technology on the 1200cc motorcycle which saved about 8#.
other advantages include not needing to maintain upright position, venting
concerns, better cold weather resistance.
disadvantages: requires purchase of new smart charger designed just for LiPo,
high price ticket
Old Oct 13, 2013 | 03:32 AM
Pagz's Avatar
C43 w/clk55 Organs
Easy 15- 20kg saving,nice!
Are there any other lithium options on the market for less?
Old Dec 9, 2013 | 09:42 AM
cm60k's Avatar
Received my friends "Voltphreaks VPR-S40 Battery" today, he told me to try it in my car, cause his car in the workshop for painting,
i will try it & let you know guys.....
ZAYED,,
Old Dec 9, 2013 | 01:57 PM
Pagz's Avatar
C43 w/clk55 Organs
Zayed,
11lbs!!! =D, did you wiegh your original?
Do you think 59Ah will have enough capacity for mercedes equipment and cranking?
Regards,
Paul
Old Dec 9, 2013 | 03:51 PM
cm60k's Avatar
Yes sure, original is Bosch 74AH (18.6kg),
i think 59AH is OK, but not sure till now, i will check it tomorrow.....
ZAYED,,
Old Dec 9, 2013 | 05:00 PM
original battery should be minimum 95 to 100Ah
74Ah is a bit low I think for all power options, ac and crank
Old Dec 9, 2013 | 06:07 PM
cm60k's Avatar
Im using 74AH since almost "6" years without any issues....!!
ZAYED,,
Old Dec 9, 2013 | 10:04 PM
RPB's Avatar
RPB
Agreed.
Old Dec 10, 2013 | 05:18 AM
ZAYED,,
on my side of the world our cars are fitted with 95 or 100 amp batteries, hotter climate countries might have weaker batteries?
Old Dec 10, 2013 | 08:30 AM
cm60k's Avatar
Put the battery in my car and try it about "4" hours with audio/ac/all lights on,
start the car many times, without any kind of problems...,
i will keep trying it for more "2-3" days & see....
ZAYED,,
Old Dec 10, 2013 | 02:04 PM
Pagz's Avatar
C43 w/clk55 Organs
On there website it shows the VRP-S40 as $1660 USD, that's pretty up there but in comparison to other light wieght mods it is not that expensive(ie my brakes cost about 2500usd and save 12.5kg)...however, assume it lasts 7 years till replacment...that's an on going cost of $237usd per year for as long as you want to save 15-20kg...I dont like the thought of definitely having to replace it one day.
Old Dec 10, 2013 | 05:58 PM
DRBC43AMG's Avatar
I'll stick with my Bosch 100 ah (changed last spring) until a cheaper solution is available. Some weight in the back end helps getting the power down on the road.
I'll save some weight other ways like some dieting. I'm aiming for a 15kg reduction and that will definitely help getting in and climbing out of my Ultima when she's finished
Old Dec 10, 2013 | 07:57 PM
Pagz's Avatar
C43 w/clk55 Organs
Lucky for some haha, if I wieghed 15kg less i'd vanish^^.
Zayed, Put 17" light wieght spare wheel from CLK55(maybe 210 as well?) weighs 17.3kg which is same wieght as my 17x8" Enkie race wheels/tires, thats 5kg's less than the stock mono/tire combo
Also it clears BBK(stoptech,brembo etc) unlike the mono spare
Old Dec 19, 2013 | 07:14 PM
cm60k's Avatar
I removed the spare "3" years ago, keep wheel arch empty,,
im using brakes from 99 C280, "2" years ago, Extra more lighter, and do the job perfectly, but of course; quickly fade-up.....
ZAYED,,
Old Dec 19, 2013 | 07:24 PM
cm60k's Avatar
Tried the battery for almost 10 days,with "0" issues, its soo BRILLIANT....,
before i got 12.29V, now its 13.32V....!!
ZAYED,,
Old Dec 23, 2013 | 02:41 PM
Pagz's Avatar
C43 w/clk55 Organs
Zayed,
Yes of course no spare is best xD
How much do your regular c280 brakes wiegh?
My battery did not come up to float today, time for a new one but I dont think it will be lithium somehow =)
Old Dec 23, 2013 | 02:59 PM
cm60k's Avatar
C280 brakes, compared to C43/CLK55/E55:-
*Front Rotors: "6.2kg vs 10.2kg",
*Rear Rotors: "3.3kg vs 7.1kg",
*Front Calipers with Pads: "4.8kg vs 7.3kg",
*Rear Calipers with Pads: "3.2kg vs 5.4kg"....
ZAYED,,
