C36 Wiring Harness
I need you help & advice. I just pick up a 1995 C36 in great shape with 99,000 kms on the clock. But unfortunitly the wiring harness is crumbling to dust before my eyes. I realize that this was a common problem for this year. So onto my problem.
I check with the dealer here & they gave me two P/N that can be used 2025400332 which is a 5 pole harness & 2025400132 which is a 6 pole harness. Unfortunitly both are no longer available in Canada. So my questions are as follows:
1) Whats the difference between these two harnesses?
2) Does any one know if the harnesses are available in the USA?
3) Are there any other harnesses that I can use.
4) Can anyone recommend someone that rebuilds these harnesses.
Thanks in advance for all of your help.
Post some pics of the car when you get a min.
Cheers.
The other P/N the dealer gave my might been a later revised harness.
Salaco, I have ASR on is car, so I do not believe that harness would work.
Thanks for the offer though.
I'll have to look into a harness from a C280 with ASR thought. I dought the dealer will be of any help.
