Eibach pro-kit
Old Jan 6, 2014 | 11:26 AM
pedrobenz's Avatar
1991 190e 2.3
Eibach pro-kit
Has anyone used the eibach pro-kit on C43? What pad number did you use and how low did it lower the car? post pics please. thanks.
Old Jan 6, 2014 | 09:31 PM
Frank Castle's Avatar
C43
I have them on mine. I used the existing pads.
https://mbworld.org/forums/members/f...0&ref=gnr-next
Old Jan 6, 2014 | 09:41 PM
pedrobenz's Avatar
1991 190e 2.3
Thanks... that is a nice C43... did you have to buy front and rear camber kits? I understand that the front are camber bolts only. Did you buy the camber kit?
Old Jan 6, 2014 | 09:46 PM
C43
No, its on the wish li$t. If i ever win the lotto its getting that and suicide doors :P
Downside= it eats tires without the alignment but I deal with it.
Old Jan 6, 2014 | 09:49 PM
pedrobenz's Avatar
1991 190e 2.3
do you know where to get camber kit?
Old Jan 6, 2014 | 09:54 PM
eFifty5AMG's Avatar
2004 E55
I believe you can purchase here. http://www.k-mac.com/pages/newprods/...ercedes_05.htm
Old Jan 6, 2014 | 10:36 PM
pedrobenz's Avatar
1991 190e 2.3
Old Jan 6, 2014 | 10:39 PM
nd4spd13's Avatar
1995 C36 AMG, 1998 C43 AMG
You can also make your own for the rear, really simply. Check out Club202
Old Jan 6, 2014 | 10:46 PM
pedrobenz's Avatar
1991 190e 2.3
thanks... i will check it out... the reason i was asking is because of alignment... i have been trying to research on lowering my C43 but i dont see a lot of people doing the camber kit. well, at least on this site. A lot of people just do alignment after lowering the car but there is nothing much to adjust after you install the lowering springs. I only see toe adjustment via the tie rods... where else do you adjust it on this C43s if you dont put the camber kits?
Old Jan 6, 2014 | 11:42 PM
pedrobenz's Avatar
1991 190e 2.3
found this - http://www.club202.com/forums/showth...ar-camber-arms
how about the fronts? what solution do we have on the front? thanks again
Old Jan 6, 2014 | 11:46 PM
eFifty5AMG's Avatar
2004 E55
found this - http://www.club202.com/forums/showth...ar-camber-arms how about the fronts? what solution do we have on the front? thanks again
Yep, that's it. You can use the K-MAC kit for more adjustment or eccentric bolts.
Old Jan 6, 2014 | 11:51 PM
pedrobenz's Avatar
1991 190e 2.3
I think this DIY should work for my rear... I may just need to buy the repair kit bolt from the dealer. I saw it on one of the post here. That may bring me close to spec. I just hope the rear toe will not be affected by this DIY kit. Thanks.
Old Jan 9, 2014 | 11:39 PM
K-Mac's Avatar
SPONSOR
Mercedes-Benz CLK 550
Yes you can fix it right the 1st time (Front and Rear) with K-MAC
Ex-factory there is only front and rear Toe adjustment for virtually all Mercedes 1968 to current models (and same with Chrysler Crossfire and 300C etc).
We saw the need and were the very first company to manufacture precisely adjustable front Camber and Caster bushing kits with twice the adjustment range of the basic one setting offset bolts.
Then for the rear, K-MAC Camber adjuster kits, which have the advantage (unlike upper adjustable arms/DIY kits) of not moving the top of the tire outwards when adjusting to resolve premature inner edge wear - which is an important factor to prevent tires scuffing outer fenders if wide profile tires/rims fitted.
Another advantage with K-MAC rear kits - unlike spherical bearings used in these upper arm kits, there is no harsh metal to metal contact and 20 years of the proven design - there’s certainly no squeaks.
Also all K-MAC rear Camber adjusters include extra Toe adjustment which is essential to compensate accurately for the new Camber facility!
The K-MAC patented design front kits replace the 4 main suspension bushes - the unique 2 axis/self aligning design also doubles the load bearing area thereby increasing wear life and also steering and braking response.
Similar design is used for the 4 main rear K-MAC bushings.
Result is precise single wrench front and rear (ongoing) adjustment to return vehicle to factory specs to improve traction, compensate for steering pull, costly inner edge tire wear through altering height, fitting wide profile tires, load carrying, curb-knock damage and/or the advantage of being able to alter specs, improve lap times on track days and with genuine K-MAC you also do not need to purchase special fitting tools.
Product confidence with K-MAC is further assured by our total, ongoing commitment to motor racing – all out 10/10ths competition testing keeps K-MAC products always at the forefront re cutting edge technology, proven strength and durability.
