anyone know anything about floor heat problems
under the hood, it's the plastic vacuum line at the rear of the engine, goes into a wiring harness right at the rear of the airbox on top. check at engine and at rubber hose. could also be unplugged under the hood on the right side by the module box.
finally you could just check the source at the switchover block, it's behind the glovebox.
i'd start there, likely it's just that if you're having other issues too.
it's a hard plastic vacuum line, gray in color. then it plugs into a rubber vacuum hose that is in the harness tray. 9 times out of 10 it is unplugged if you have the problem you're describing.
