need help c43 wont start no crank nothing
Old Jan 25, 2014 | 07:40 PM
k.trueno's Avatar
C43 AMG
I need help on my c43 wont start just a clicking sound coming from the comfort module but all power are okay window, doors, seats, everything but it wont turn over when I turn the key to start position but it has BAS/ESP light on but I have this for a month until now I wonder if cause the no start. please help.
1999 C43 with 154,000km
Old Jan 25, 2014 | 09:30 PM
Sulaco's Avatar
1999 C43 AMG, 2005 E55 Wagon
Judging by your apparent knowledge I guess we're safe to assume you've already made sure the battery is charged appropriately.
Where is this "comfort" module you speak of? The one in the trunk beside the battery?
Perhaps your immobilizer has tripped? Key has failed?
Old Jan 25, 2014 | 10:36 PM
k.trueno's Avatar
C43 AMG
yes I did charge the battery but still nothing when I turn the key to start position and for that module front floor passenger side it has a sticker k12 but I search the part number it say comfort module. any Idea what have cause this no start? thank you for the reply
Old Jan 25, 2014 | 10:42 PM
k.trueno's Avatar
C43 AMG
how do I check if my immobilizer tripped? the car still recognize the key it locks unlocks and turn on the all the powers but it wont start? thank you
Old Jan 26, 2014 | 03:32 PM
vlad957's Avatar
1998 C43 Amg
I'm not sure but it could be your crank postion sensor too. Our c43s tend to have those problems. If the crank postion sensor goes bad then the car won't start. Or could die out while driving. That's what's happening to me right now. I'll start my car and it will die immediately. I'll have to try two times just to start it lol. You could try to replace the sensor and see if that helps.
Old Jan 26, 2014 | 05:28 PM
k.trueno's Avatar
C43 AMG
I was thinking it might be the starter or battery cause mine was running smooth and now it wont start when I turn the key nothing happen all light and powers are on and working except it wont crank.
Old Jan 27, 2014 | 07:29 AM
DRBC43AMG's Avatar
If your light are on and bright and all the other electrics work normally, the battery is fine. How much is the voltage across the + and - poles?
Old Jan 27, 2014 | 10:39 PM
k.trueno's Avatar
C43 AMG
it's reading 13.3v but I am gonna get a new one tomorrow cause i think the battery of this is old, I hope it will fix it. let you guys know and I hope it's not cold like today -43 here
Old Jan 28, 2014 | 03:25 AM
DRBC43AMG's Avatar
-43 Fahrenheit I imagine, that will kill any battery and freeze your ***** off!
Old Jan 28, 2014 | 09:31 AM
k.trueno's Avatar
C43 AMG
it's Celsius but I am gonna get a new battery today cross finger I hope it will start.
Old Jan 28, 2014 | 10:54 AM
KJI3jflarryfe93's Avatar
probably you battery froze and died?
are you located near Siberia having -43C?
you must be near Scandinavia or Russia, these areas are known to be cold as hell is hot?
that's seriously cold freezing your nuts off!
antifreeze did you check this on your car?
Old Jan 28, 2014 | 12:09 PM
k.trueno's Avatar
C43 AMG
No I am in Canada Winnipeg MB yes it is cold here what do you guys think of AGM battery?
Old Jan 28, 2014 | 03:28 PM
mkoons's Avatar
1999 C43
AMG Battery
Battery is standard factory battery. I just installed the 3rd factory battery in my C43 in 15 years. 122,000 miles, can't beat that. Cost $230 US. And I live in So Calif desert, we have 4 months of 105 to 115 degree temps, AC runs almost year round.
Old Jan 28, 2014 | 05:20 PM
Sulaco's Avatar
Replaced factory original battery in my 1994 C280 in about 2003 with 150k miles. Never bought another battery, sold it in 2011 with 255k miles.
unimoged's Avatar
C43, S500, S320, 280 SEL 4.5
It is probably your starter solenoid. To check it, disconnect the wire coming to it from the ignition start circuit. Then with a 20 amp fused lead, run 12 volts to it from the 12 V main terminal on the starter. It is the major cable that comes from the battery. If it does not engage and turn the engine than it is your solenoid. If it cranks the engine than it is in the ignition start circuit.
Crank sensor has nothing to do with this problem.
Old Jan 30, 2014 | 10:40 PM
k.trueno's Avatar
C43 AMG
okay I check my starter and it fail. I am just wondering if I can use the starter out from the 2001 s500? I am just wondering if they are compatible
Old Jan 30, 2014 | 11:35 PM
Ausmbtech's Avatar
190D 2.5 (x2), 190E 2.6, W202 C240,W202 C43 (C55), W210 E55, W212 E250CDI
Starters for all M112 and M113 's are the same as long as they are on same side of the block.
Old Jan 31, 2014 | 12:20 AM
k.trueno's Avatar
C43 AMG
should I replace the whole thing or just solenoid ? I am new to this German engineering
Old Jan 31, 2014 | 01:21 AM
Ausmbtech's Avatar
I'd just change the whole thing, they are pretty cheap. Used should be ok, they rarely give trouble anyway.
