Battery Light on for a minute
Old Feb 8, 2014 | 06:25 PM
venturaexit's Avatar
1999 Mercedes Benz C43
Does this means the battery is dying?
or maybe I should read the manual.
Old Feb 8, 2014 | 06:36 PM
KJI3jflarryfe93's Avatar
i don't have that light on my car, what is it?
Old Feb 8, 2014 | 07:38 PM
mercedes4ever's Avatar
2004.7 C180 Kompressor, BMW X5, Chevrolet Camaro LT, Mercedes S, Cesna 152.
Could be, or might be your alternator is not charging. Have you checked your volts?
1. Make sure mileage display is showing on dash, turn key to pos 1
2. press reset button 3 times quickly [audible beep].
3. Displays your volts.
Old Feb 8, 2014 | 07:59 PM
Tony_AMG's Avatar
1999 C43 AMG
Its the low coolant lamp. Check your coolant level, must be low. Add water / Coolant to top off.
Old Feb 8, 2014 | 08:13 PM
You are correct!
Old Feb 9, 2014 | 09:06 AM
yup then i have this, didn't recognise the lamp
Old Feb 10, 2014 | 07:32 PM
yeah Tony, correct.
what's the best coolant I should use? and mixed w distilled water right?
Old Feb 11, 2014 | 03:02 AM
Tony_AMG's Avatar
1999 C43 AMG
Yes mix in 50/50 solution. As for Coolant, up to you, but i would rather buy a Full gallon of Genuine MB coolant and go 50/50 with water. That is what MB/AMG recommends in the books, but up you to honestly if you willing to spend like $20 or so in coolant.
Old Feb 11, 2014 | 08:45 AM
Thank you Tony, I agree on MB coolant.
Old Feb 11, 2014 | 10:44 PM
Tony_AMG's Avatar
1999 C43 AMG
Your welcome! C43AMG OUt!@
