Water pump, and what else?
So, aside from the pump and likely the thermostat, what else should I do while I'm in there? Does anyone know of a good write up for this procedure with steps, and pics if possible?
Thanks in advance
If you're doing the water pump I would suggest you replace the upper idler pulley while you're there. You can usually only do it when the radiator is out or pushed forward as the bolt for it is too long.
