Valve cover gaskets
Old Apr 17, 2014 | 10:51 PM
88260EEE's Avatar
1998 C43, 05 Mini Cooper s
Valve cover gaskets
Did the valve cover gaskets today, with the PITA breather covers
Old Apr 17, 2014 | 10:52 PM
88260EEE's Avatar
Old Apr 17, 2014 | 10:53 PM
88260EEE's Avatar
Drying the drivers side!
Old Apr 17, 2014 | 10:54 PM
88260EEE's Avatar
Old Apr 17, 2014 | 10:58 PM
88260EEE's Avatar
Valve covers were easy, but the breather covers sucked ***!!! That 16yr old sealer was like cement!
Old Apr 18, 2014 | 02:14 AM
Pagz's Avatar
C43 w/clk55 Organs
Well done!!, yeh those chamber covers are a pain
Old Apr 18, 2014 | 02:38 AM
DRBC43AMG's Avatar
Did you change the plugs when the covers where off? So much easier to do as access to those critters suddenly becomes greater
Old Apr 18, 2014 | 11:11 AM
88260EEE's Avatar
No should have did the plugs but I did not have that puller wrench, need to get one
Old Apr 18, 2014 | 12:54 PM
DRBC43AMG's Avatar
Don't forget the perfect tool for removing the plug boots is an open ended 17mm wrench which has been suitable bent to fit. A non bent open 17mm will also work (it has for me...) but you have to be careful not to snap the plug (it can happen).
Old Apr 20, 2014 | 08:51 PM
Vicious_c43's Avatar
'98 AMG C43 / '70 Cougar
torque specs
Sup guys! what's the torque spec on the valve covers? I read somewhere it's 72 inch lbs, is this correct?
And also what's the torque specs on the baffle's?
I'll be replacing the valve cover gaskets / reseal the baffles / replacing spark plug and wires soon...just waiting on parts.
Old Apr 20, 2014 | 09:06 PM
benzslo's Avatar
C43 5.4, ML320CDI, Fords
yep i've probably done 100 of them, sometimes that sealer is a real pain to get off. and i'm even using a hot solvent tank for most of it. But it feels real nice when it's all back together and clean.
Also it's good to make sure you blast off and blow out all the crud that is sitting directly above the valve cover on the head before removing the cover, so that doesn't fall into the head when the cover is removed.
Old Apr 20, 2014 | 09:41 PM
88260EEE's Avatar
True!!!
Old Apr 20, 2014 | 09:54 PM
Pagz's Avatar
C43 w/clk55 Organs
Specs for you:
Cam cover to cylinder head - 9Nm
Small alloy screws that must be replaced on chamber covers, new MB ones are steel - 4Nm.
Coils to cam cover - 8Nm
loctite 5970 or 50ml MB A003 989 98 20(really need mb corking gun for 50ml canister) - Bead spec 2.0mm.
Cheers.
Old Apr 20, 2014 | 10:14 PM
Originally Posted by Pagz
Specs for you:
loctite 5970 or 50ml MB A003 989 998 20(really need mb corking gun for 50ml canister) - Bead spec 2.0mm.
Cheers.
Thanks Pagz! more info than I wanted. Yeah I've ordered the parts you've mentioned screw for the chamber covers and MB black sealant, should be arriving this Wednesday...cant wait next weekend to do the job it's been leaking bad.
