1994 C36
Old Apr 25, 2014 | 10:47 AM
run115's Avatar
Alfa Romeo 155
1994 C36
Hi All, am looking at getting a black c36 with 60,000km's. It is a one owner, no rust full service history. What should I look out for at a test drive and in general? The obvious things which I saw are the roof lining needs glueing back from the sunroof side, and it needs a good clean.
Thanks!!
Vince
Old Apr 25, 2014 | 11:14 AM
DRBC43AMG's Avatar
Welcome aboard. If the c36 has really only that amount of kms on the clock, you have practically a new vehicle.
I am not a specialist of the 36, but others that are will surely be along soon. From comments heard and read on this forum and elsewhere, I think that these models suffer mostly from perishing engine wire looms. They are expensive to change using OE supplied materiel, but other cheaper solutions exist.
When you test drive, check also that the transmission and gear changes are smooth, with no clunking or whines, or leaks anywhere. If you finally go ahead and purchase the 36, I would recommend you change ALL the fluids (oils, ATF, brake fluid, cooling system), not unless proof is given that all this has been kept fresh and up to date.
Check rubber related items which could be cracked, brake lines, joints, etc.
In all cases, keep us informed on your final choice
Old Apr 25, 2014 | 06:57 PM
RPB's Avatar
RPB
Check the engine harness!
Old Apr 26, 2014 | 01:19 AM
run115's Avatar
Alfa Romeo 155
Cheers guys, how do I check the harness? Is this something visible that I can check once I open the hood or should I take it to a pro?
Old Apr 26, 2014 | 08:45 AM
RPB's Avatar
RPB
This will help:
GL!
Old Apr 27, 2014 | 03:43 AM
DRBC43AMG's Avatar
Informatif video. Nice find.
