Headlight mod (with W211 Bi-Xenon)
Subscribe
May 7, 2014 | 12:16 PM
Hi,
modified my head lights with inserting W211 Bi-Xenon modules (Hella device).
It was a little difficult to make them fit into the original reflector and adjust the modules in x/y direction and rotation to the additional high beam and fit into the housing. The cap did not fit any more because the module is longer, so I needed to find another solution. The clear front cover polycarbonate is from some after sales headlights. I needed to create adapters to get them in original position and make them fit on the housing sealing.
Reply 0
May 7, 2014 | 12:17 PM
Reply 0
May 7, 2014 | 12:41 PM
Amazing. Your car just keeps getting better and better.
Reply 0
May 7, 2014 | 06:06 PM
Quote: Amazing. Your car just keeps getting better and better.
+1
Amazing work
Reply 0
May 7, 2014 | 06:18 PM
I think there should be an mbworld field trip to Germany to visit Popeye and his car (and the Mercedes and Porsche museums, and the Nurburgring and probably Oktoberfest too)
Reply 0
May 7, 2014 | 07:23 PM
Nice!!
Reply 0
May 7, 2014 | 08:04 PM
Quote: I think there should be an mbworld field trip to Germany to visit Popeye and his car (and the Mercedes and Porsche museums, and the Nurburgring and probably Oktoberfest too)
That would be so sick.
Reply 0
May 8, 2014 | 12:24 AM
Looks nice! I wonder how it would look if you blacked out the inside art of the headlight...
Reply 0
Explore
May 8, 2014 | 03:36 AM
I like the mod How do you get around the self leveling which normally is mandatory when using those type of lights, or are you using the original system?
Reply 0
May 8, 2014 | 06:40 AM
Is is all factory standard. I 'just' replaced the low-beam reflector with the new module. Cutting a hole into the reflector and mounting a frame into the reflector. The frame must fit rather tight around the module, otherwise you won't be able to screw the reflector into its housing anymore. Before finally fixing the frame, it is necessary to adjust the rotation. Then I used 4 screws to link the module to the frame. With These screws I adjusted the module to the aditional high beam reflector, becaus later you can adjust the headlight from outside adjusting both reflector and modul together only, so it must be adjusted to each other.
Reply 0
May 8, 2014 | 08:31 AM
Nice work! That car should have come that way from the factory
Reply 0
May 19, 2014 | 07:22 AM
Headlights are certified now and with the 3rd attempt I now have real optic free blinkers. Unfortunately they don't fit like the factory ones.
The parking light is integrated behind the lense (LED).
Reply 0
May 19, 2014 | 07:26 AM
Great job Popey..,
seems like you want me to sell my car MaaaaaN....
ZAYED,,
Reply 0
May 19, 2014 | 12:32 PM
Great job as usual Do you need to get TüV approval of the lights? Here in Switzerland this would probably mean getting the stuff certified with a technical inspection and tons of paper approvals You should have seen what I had to go through for the KW suspension and SS flex hoses. Luckly the drilled rotors passed without any comments
Reply 0
May 19, 2014 | 12:48 PM
Quote: Great job as usual Do you need to get TüV approval of the lights? Here in Switzerland this would probably mean getting the stuff certified with a technical inspection and tons of paper approvals You should have seen what I had to go through for the KW suspension and SS flex hoses. Luckly the drilled rotors passed without any comments
now i know why switzerland turned down Jas 39 Gripen
too much paperwork to get these planes TÜV approved
Reply 0
May 20, 2014 | 06:44 PM
I guess the CHF 5 billion was also a bit difficult to swallow. We will stick with our fleet of Tigers and FA18's, not unless the europeans come back with nice offers for the Rafale or Eurofighter. In any case the air-force only flies during office hours (I'm not joking)
Reply 0
May 20, 2014 | 07:33 PM
Wow! Excellent work! You're skills are exceptional!
Reply 0
Subscribe
Currently Active Users (1)
