Fuel Tank sender units & Strainer
Old May 13, 2014 | 03:43 AM
cm60k's Avatar
Yesterday i replace "2" fuel tank sender units & strainer, nothing wrong with oldies, just during the age,,
does anyone know if these units only for cluster reading or they got another functional..?!!?
Fuel Tank sender units & Strainer-2024703941.jpgName:  2084701041.jpg
ZAYED,,
Old Jul 13, 2014 | 08:59 AM
Twichel04's Avatar
1996 C36 AMG and 1999 BMW e46
How bad was the job? I need to do this too.
Old Jul 13, 2014 | 12:08 PM
cm60k's Avatar
It's not that hard, just need to get the tool to do it easily & properly..
Name:  MB fuel sender unit tool 1.jpg
Size:  9.3 KBName:  MB fuel sender unit tool.JPG
ZAYED,,
Old Jul 13, 2014 | 12:28 PM
KJI3jflarryfe93's Avatar
zayed, do you work from trunk to remove these senders?
Old Jul 13, 2014 | 12:30 PM
benzslo's Avatar
C43 5.4, ML320CDI, Fords
Fuel gauge reading. Also, for USA models and maybe others, there is a pressure sensor in one, right side I believe. It is for the fuel evaporative purge system.
Old Jul 13, 2014 | 12:41 PM
cm60k's Avatar
Dennis,
Nothing to do with trunk, have to jack the car & remove L/R covers, they are located at the bottom of the fuel tank..,,
little fun job...
ZAYED,,
Old Jul 13, 2014 | 12:54 PM
cm60k's Avatar
Good point,
i didn't know U.S models got pressure sensor..!,
i thought they got Purge valve & shut-off valve only...!!
Fuel Tank sender units & Strainer-0004703593.jpgFuel Tank sender units & Strainer-fuel-shut-off-valve.jpg
ZAYED,,
Old Jul 13, 2014 | 01:05 PM
Originally Posted by cm60k
Dennis,
little fun job...
Attachment 291107
ZAYED,,
daem bro, i thought it was a comfortable job from the trunk, removing plastic cover under carpet and voila fuel senders in front of me, my old volvo had the sender in trunk.
should you have an almost empty gastank when removing both senders?
would there be a gasleak if tank is full when senders are removed?
good to know thanks
Old Jul 13, 2014 | 01:17 PM
cm60k's Avatar
Yes it should be bro.,
if you open the senders all fuel will fall-off completely,,
you can empty the tank, via the fuel pump hose, or air pumped/sucked via the cap, then return it again when new senders were installed...
ZAYED,,
