Puzzled!!!
Old May 30, 2014 | 09:02 PM
nkctb7's Avatar
2006 E55 AMG/1996 C36 AMG/1999 C43/55 AMG/2021 Toyota Tundra Crew Max TRD Sport Premium
Puzzled!!!
Hey Guys,
CEL on. Car was running rough and severely hesitating as it was misfiring. I ran a diagnostic and cylinders 5,6 & 7 were misfiring. I swapped the plugs & wires with cylinders 1,2 & 3 to see if I could pinpoint the problem. I erased the codes and drove it for two days. Same problems with no change whatsoever. Usually the CEL will reappear as soon as I put the pedal to the floor and the hesitation/misfiring occurs. No CEL present and I cannot pinpoint the problem. I am guessing that it is the MAF but wanted to check if anyone has encountered a similar situation. I was under the impression that a bad MAF or TPS would show up on a diagnostic. I'm using a MaxiDiag Autel EU702 and has it been very accurate. Any help would be greatly appreciated.
Cheers
Old May 30, 2014 | 09:21 PM
Sulaco's Avatar
1999 C43 AMG, 2005 E55 Wagon
Check pending codes?
Old May 30, 2014 | 10:10 PM
nkctb7's Avatar
Hey Sulaco,
That is the problem as there are now no codes when I perform a scan but the problem still persists.
Old May 31, 2014 | 01:17 PM
nkctb7's Avatar
I think I may have found the problem. A leaking cylinder head gasket resulted in oil leaking into cylinders 5,6 & 7. I will replace left and right gaskets as well as all new plugs and possibly wires.
Cheers
Old May 31, 2014 | 02:06 PM
cm60k's Avatar
Glad you found the problem D.,
also leaky fuel or coils or s.plugs could do that, especially when get HOT....!!
ZAYED,,
