bad brakes
Old Jun 16, 2014 | 06:07 PM
  #51
nd4spd13's Avatar
1995 C36 AMG, 1998 C43 AMG
Originally Posted by Pagz
Zayed,
Yes all Ecu,Tcu,Prop/Diff/Axels/Subframe,Trans,Eis,Touchshifter/Harness,multifunction steering,cluster,Radio. Only problem no rear window actuation(clk55 EIS coding),still working on this.
Er, hold on, you put that all in a 202???
Where, oh where are all the pics?
Also how did you get EGS52 to work? Did you re-cut the hole in the trans tunnel?
Old Jun 16, 2014 | 06:18 PM
  #52
cm60k's Avatar
+1,
Thread here..,
http://www.club202.com/forums/showth...K55-Conversion
Paul, what about starting NEW thread here, with some good photo's...
ZAYED,,
Old Jun 16, 2014 | 06:53 PM
  #53
nd4spd13's Avatar
Originally Posted by cm60k
+1,
Thread here..,
ZAYED,,
This is awesome. I know what I'm going to be doing for the next hour....
Old Jul 10, 2014 | 01:25 PM
  #54
raw1879's Avatar
Mercedes C55 AMG
the master cylinder on the left of picture is my original one the one on the right of picture is from a sl600. the sl600 cylinder is too sort and will not fit my car so ill keep the one I changed from a clk 430
Old Jul 10, 2014 | 02:14 PM
  #55
KJI3jflarryfe93's Avatar
is there an improved difference between clk430 master brake cylinder vs C43 bmc?
for my c32/c55 brakes maybe i should get the mbc from c55amg?
Old Jul 10, 2014 | 02:42 PM
  #56
cm60k's Avatar
What's the problem with short or long..?!?, i put that in my "3" previous C43's without any issue...!!
ZAYED,,
Old Jul 10, 2014 | 03:35 PM
  #57
raw1879's Avatar
Mercedes C55 AMG
ZAYED,,
ok then ill try it thank you
Old Jul 12, 2014 | 11:41 PM
  #58
Pagz's Avatar
C43 w/clk55 Organs
Guys,
Very early E55/C43 (C43 upto ident F737081) had A005 430 83 01(I think this is 23/19 combo)
later E55/430,CLK55/430,C43 (C43 after Ident F737082) had A005 430 88 01(25/22 combo)
All 98 C43 we have here are ~F75**** so must have been VERY early C43 only with 23/19?.
Mine is 99 F780045 so already has 25/22 combo.
Cheers..
Old Jul 20, 2014 | 08:59 PM
  #59
nhmercracer's Avatar
I would wager the M/C on the left is used with the dual diaphragm brake booster.
