CL600 Calipers?
Old 08-24-2014, 11:11 PM
Twichel04's Avatar
1996 C36 AMG and 1999 BMW e46
CL600 Calipers?
I may have found a good deal on a local set of calipers off of a CL600... will these bolt on to a C36? I am pretty familiar with w201 brake upgrades, but I am on uncharted waters when it comes to w202 upgrades.
Old 08-24-2014, 11:57 PM
cm60k's Avatar
00 C200 & 00 C55 & 06 SLK55
Do you have picture of those calipers..?
ZAYED,,
Old 08-25-2014, 12:00 AM
Twichel04's Avatar
This is not a picture of the actual caliper I am looking at, but it is the same one. From what I understand, these are the same calipers as the w203 c32? I could be wrong though.
Old 08-25-2014, 12:07 AM
MBworld Guru
OCKlasse's Avatar
04 CL55, 05 E500S4, 15 BMW i3 REx
They bolted right up on my 202 (these were off a CLK550).
Old 08-25-2014, 12:11 AM
Twichel04's Avatar
What do you guys usually see these going for? I want to make sure that I am actually getting a good deal, lol.
Old 08-25-2014, 12:29 AM
cm60k's Avatar
I think those W220/W215 S/CL600 using the same C32/C55 Rotors, which is 345x32..
ZAYED,,
Old 08-25-2014, 02:41 AM
raw1879's Avatar
Mercedes C55 AMG
i dont think the cl calipers will fit without spacing out the rotor. best to get w209 or w203 4 pot calipers thy bill bolt right up
Old 08-25-2014, 03:36 AM
KJI3jflarryfe93's Avatar
did you replace your brake master cylinder when you changed your calipers or do you still use the factory fitted c43 BMC?
Old 08-25-2014, 01:41 PM
cm60k's Avatar
Assuming they will fit, may need washers & spacers, depend to the Rotors will chosen,
i tried some of W220 calipers on my & my friends W202/W208/W210,,
312x28 & 330x32 & 334x32 & 345x30 & 360x36..
ahh i forget, i have a good helper, but she's soooooo laaaaaazyyyy..
CL600 Calipers?-picture-790.jpgCL600 Calipers?-picture-791.jpgCL600 Calipers?-picture-792.jpg
ZAYED,,
Old 08-26-2014, 10:17 PM
Twichel04's Avatar
Well, I went ahead and bought the calipers. They were a good enough deal that they were worth it to try out. If they work, I got a cheap upgrade. If not, I should have a problem getting my money back.
Old 08-27-2014, 07:09 AM
cm60k's Avatar
Forward some photos, need to be sure if they using 330mm or 345mm..?
ZAYED,,
Old 08-27-2014, 11:21 AM
Twichel04's Avatar
These are the actual calipers that I bought. Not sure if you can tell anything from that. I will take better pictures and get part numbers off of them once they get here.
Old 08-27-2014, 11:30 AM
cm60k's Avatar
They looks good,
you will need Rotors from C30/C32/C55/CLK500/CLK550/SLK55 with or without p30,,
or you can get less weight Rotors from RB racing brakes..
ZAYED,,
Old 08-27-2014, 04:45 PM
there are some numbers stamped back of the calipers
look for digits 345mm
Old 08-27-2014, 05:09 PM
cm60k's Avatar
Hey Dennis,
Where did they stamped the Rotor dia...?, i didn't see it in all calipers around me..!
ZAYED,,
Old 08-27-2014, 05:54 PM
Originally Posted by cm60k
Hey Dennis,
ZAYED,,
hey bro
please see the backside of the caliper housing, there are lots of numbers stamped on the sides of rear caliper housing.
in this picture you can see a few manufacturers numbers
somewhere on caliper housing you will see the 345mm digits
Old 08-27-2014, 06:01 PM
popey24's Avatar
C43 AMG 5.5 - 396.4HP
Pay attention to the rotation direction! Some weeks ago someone here spend a lot of time on that problem and I think he found a nice solution. Search for topic C32 brakes...
Old 08-27-2014, 07:19 PM
cm60k's Avatar
Originally Posted by kowalski
hey bro
Thankss alot bro., i saw those Brembo factory #s, but i didn't find the dia. ID of the Rotor...!
ZAYED,,
Old 08-27-2014, 07:21 PM
cm60k's Avatar
Hey Popey, i put C32/C55 brakes many times never had any issues..!, what kind of risky will cause about those brakes..?
ZAYED,,
Old 08-27-2014, 10:16 PM
Super B's Avatar
'97 c36
Think he might be talking about me. and getting the piston orientation correct. I had to swap the piston plates and make up some hard lines to get the pistons in the right order and the bleed valve up.
Old 08-27-2014, 11:21 PM
cm60k's Avatar
Didn't get that..!, which piston plate..?
ZAYED,,
Old 08-28-2014, 12:17 AM
Super B's Avatar
'97 c36
Well, the pistons in the caliper are not equal in size. So if if you just bolt them on the car with the bleed screws up, the larger piston will be on the first piston to apply the pressure to the disc.
Now Brembo/Mercedes didn't design it to work that way. but I've read several people doing it and personally know a guy with a c280 who bolted them on and he swears it's fine. Maybe it is maybe it isn't. It would be nice to see some stopping distance tests and data. I personally didn't run them that way.
The work around as some people do, is to swap the calipers to the different sides of the car. This will get the piston order correct but will point the bleed screws down. As well as require a brake line modification as the stock lines will be too short.
If you do not want your bleed screw down. Then bolt the calipers on the car with the bleed screws in the up position. Then unbolt the piston plates from the caliper frames and swap them to the other side of the car. This will get the pistons in the correct order as well as the bleed screws in the up position. But will still require a brake line modification and touch up paint.
This is why some people just bolt them on the car even with the piston order wrong.
Then use the sprinter brake pad sensors you suggested.
Old 08-28-2014, 12:51 AM
cm60k's Avatar
Thanks for that useful explanation,,
100% agreed, upside down bleeder will create pressure, then pistons & seals will suicide..
ZAYED,,
Old 08-28-2014, 03:36 AM
ZAYED,,
my calipers have 345 digits stamped somewhere back of the calipers, check more thorough
Old 08-28-2014, 03:41 AM
when you swapped drivers side/passengers side front piston plates to get the correct piston in order to work correctly, isn't the rear piston back plate still on the wrong side on both left/right calipers with bleeder valve pointing up.
what i'm trying to say is, the larger piston kicks in first on rear plate and on the (swapped) front plate smaller piston kicks in first???
am i wrong here?
Quick Reply: CL600 Calipers?
