Good job MaaaaaN, this is one of great upgrade, will gives more life to brakes..
ZAYED,,
ZAYED,,
Quote:
ZAYED,,
Thanks Zayed I hope it will be affective like my other modsOriginally Posted by cm60k
Good job MaaaaaN, this is one of great upgrade, will gives more life to brakes..ZAYED,,
nice ingenuity!
but just keep in mind that usually its the pad temps that get overheated at the track, not sure if pushing air to the bottom of the disks will do much for the pad temps. most high performance street pads top out at 800* or maybe 900*F then start to fade or cant properly expel the dust. i had to go to a race pad that can still operate around 1100-1200*
*edit... just read your sig... you have the pagid race pads and they still were givng you those issues?!? that seems strange to me.
Originally Posted by Dziner82
nice ingenuity!but just keep in mind that usually its the pad temps that get overheated at the track, not sure if pushing air to the bottom of the disks will do much for the pad temps. most high performance street pads top out at 800* or maybe 900*F then start to fade or cant properly expel the dust. i had to go to a race pad that can still operate around 1100-1200*
Hi ive not used the pagid pads yet Monday will be the first time ill use race pads on track. I over heated the factory pads at the ring.
What the best way to bed in the pagid pads?
DRBC43AMG
close
- Join DateMar 2010
- LocationLand of mountains, cheese, chocolate and watches
iTrader Positive Feedback0
iTrader Feedback Score(0)
- Vehicle(s) I drive12' W204 C63 AMG coupe "T-Rex", 12' W451 Smart Fortwo Pulse (99' W202 C43 AMG + Ultima Can-Am sold)
Liked:323 Times in 268 Posts
Originally Posted by raw1879
Hi ive not used the pagid pads yet Monday will be the first time ill use race pads on track. I over heated the factory pads at the ring.What the best way to bed in the pagid pads?
sorry for not replying sooner.
i was really worried about trying to bed pads at 100+ mph as the websites often suggest for race pads, obviously trying to do this on the street is really stupid and unsafe.
I called the manufacturer of my pads, Porterfield, and talked to them about this and they told me that the key was just to get the pads to temp gradually. so they told me to do stops from 60mph; 2 stops with easy braking, then 2 more with medium braking, then 2 with hard braking.
that worked for me just fine, the pads are great. BUT that was that particular manufacturer, i would call and talk to someone at pagid to make sure that would work for your pads as well. race pads are not cheap so you dont want to waste a set or have them not work properly!
