replacing the caliper bleeder valve/nut
when i did my brake rotors and pads we found that the front drivers side bleeder valve nut was pretty badly worn and almost impossible to open and close. i looked on pelican and didnt see a part for just this valve/nut.
or it seems these are generically available if you know the size/length, anyone have info on what size we need?
thanks.
WA 210 420 01 55
looks like they can be found online for $20-27 range. no info on size.
also i do know that the front and rear bleeder screws are different sizes, im only referring to the fronts here.
Last edited by Dziner82; Apr 24, 2015 at 04:49 PM. Reason: added more relevant info
-Luccia
thanks for the response. i did find them on pelican and placed the order with a couple other things
just a note though they dont show up when searching for brake parts for the C43, i only found them by typing the part # directly into the search bar. and i had to call the dealer to get the part #, so it was a bit more work but would have been nice to have them show up in the brakes section.
but still glad that you have them, you usually have everything
it said that they were special order.
it said that they were special order.Thank you for the recommendation and heads up about the search issue. I will speak with our web people and make sure we can adjust that. If you have any other questions please let me know!
-Luccia
I just got an email notice that the bleeder valve is no longer available.
-Luccia
