Renntech CF Intake for M113 for sale
Old Jul 30, 2015 | 03:11 AM
55 ON IT's Avatar
W208 CLK55K, GTR, RS5
https://mbworld.org/forums/engine-pe...ters-m113.html
Old Jul 30, 2015 | 08:07 PM
speed43's Avatar
1999 C43 Amg
Can I ask what's the benefit besides lighter?
Is the inside ported for smoother air flow?
Old Jul 30, 2015 | 09:12 PM
nkctb7's Avatar
2006 E55 AMG/1996 C36 AMG/1999 C43/55 AMG/2021 Toyota Tundra Crew Max TRD Sport Premium
PM'd you!
Old Jul 30, 2015 | 11:00 PM
speed43's Avatar
1999 C43 Amg
Originally Posted by nkctb7
PM'd you!
I haven't received a pm yet.
Old Jul 31, 2015 | 02:16 AM
nkctb7's Avatar
I apologize Speed as I should have quoted the op as I PM'd him.
Old Aug 11, 2015 | 09:33 PM
benzslo's Avatar
C43 5.4, ML320CDI, Fords
Yes the inside is opened up alot compared to the stocker.
Old Aug 11, 2015 | 10:05 PM
eFifty5AMG's Avatar
2004 E55
How much vs. a gutted stock airbox?
Old Aug 11, 2015 | 11:08 PM
cm60k's Avatar
I believe cold air should to be considered more than smoother or more air flow,
while "Renntech" still the same position as stock, then don't see that good benefit with it..!!
*don't take that as GENERAL, just my own opinion..
ZAYED,,
Old Aug 11, 2015 | 11:35 PM
benzslo's Avatar
How much what? It is significantly more open compared to stock.
Old Aug 11, 2015 | 11:43 PM
benzslo's Avatar
ZAYED,,
HP is all about airflow, more air in and out, more power. That is going fast 101.
I'm not sure what you're talking about with cooler air. Renntech and stock both pull air from outside of the engine compartment at front of radiator. That is about as good as you get as far as that is concerned.
I really am baffled that you think two airboxes being in the same position means same outcome? I don't know what to say to that other than, no.
Old Aug 12, 2015 | 12:15 AM
cm60k's Avatar
Any idea of being against the direct heat from intake or Exhaust manifold, i'll completely agree with it,
C43/CLK55/E55 box sits right over the top of the intake manifold which get very hot, so where that damn heat is going, as Example of 55K boxes; they are actually running against the side of intake manifold which would appear to be more effective in terms of feeding the motor with cooler intake air..!
*you may don't like the idea, but as i stated; this is my own opinion, no need anyone to follow it or agree with it..
ZAYED,,
Old Aug 12, 2015 | 06:03 AM
DRBC43AMG's Avatar
To reduce radiated heat from the manifolds and block, has anyone tried placing gold sheeting under the intake box? Like this stuff which I am using in my Ultima Can-Am build: http://www.nimbusmotorsport.com/Prod...8314&CATID=268
Old Aug 12, 2015 | 11:53 AM
eFifty5AMG's Avatar
2004 E55
Was curious if there still is a significant separation (and noticeable gains) between a gutted airbox & a Renntech.
Old Aug 12, 2015 | 12:01 PM
eFifty5AMG's Avatar
2004 E55
I have thought about this as well. I had some data logged files that were lost when I updated my phone, but I have a general idea of temperatures. It'd be interesting to see if, and by how much, temperatures were effected after applying a material. Correct me if I'm wrong, but this wouldn't be removing the heat, but simply averting it away from the box in order to achieve lower intake temps.
Old Aug 13, 2015 | 12:20 PM
DRBC43AMG's Avatar
Yes, same assumption as me. Reducing airbox temp = better breathing engine.
Old Aug 14, 2015 | 01:05 AM
cm60k's Avatar
+10000000001..
ZAYED,,
Old Aug 14, 2015 | 10:09 AM
ECTurboGSX's Avatar
98 C43, 15 Alfa 4C LE, 18 Tesla Model 3 DM Perf, 08 Duc S1000, 02 Duc 998, 98 Duc 748, 01 Miata
I have some foil tape (not gold) sitting in the garage and I was planning to give this a try as well. I had some on the old 300ZX race car on its airbox (which hung out over the radiator). I'm guessing that the AMG airbox may be made from polypropylene, which has very low surface energy and that means that things don't like to adhere to it. So you may need to use an adhesion promoter to get the foil to stick. It's on my (long) list of things to do when I have time to work on the 43.
Old Aug 14, 2015 | 11:14 AM
Speedriven1's Avatar
Speedriven
I would love to see some data on this. I don't recall seeing lower IATs with/without airbox when I worked at RT a few years ago.
Old Aug 14, 2015 | 11:16 AM
Speedriven
The airboxes are wet lay-up, similar to fiberglass. They don't have the radical weight benefits you'd get with the baked/autoclave-d sort of dry carbon you might be thinking of. Same goes for CF hoods, roof panels, etc. Often they're not much lighter (or, at all lighter) than aluminum.
Old Aug 14, 2015 | 11:33 AM
cm60k's Avatar
Agreeeeeeed..
ZAYED,,
Old Aug 19, 2015 | 08:04 AM
ProjectC55's Avatar
C43/55,2k11 Volvo S60 T6AWD,2k Audi B5 S4,95 Eagle Talon Tsi AWD 500+awhp
ZAYED,,
+1000000000 anything sitting over the manifold will suck in a lot of heat the compressor intake setups are much superior in comparison.
Old Aug 19, 2015 | 08:11 AM
cm60k's Avatar
ZAYED,,
Old Aug 19, 2015 | 09:42 AM
speed43's Avatar
1999 C43 Amg
Does anyone have pictures of the inside?
Old Aug 19, 2015 | 09:48 AM
speed43's Avatar
1999 C43 Amg
This air box is awesome. It's for a C63.
Old Aug 19, 2015 | 10:58 AM
SDR's Avatar
SDR
'99 C43, '12 C63, '13 E350, '14 Sprinter
Here's a bunch of pics from when I did my Renntech airbox and ECU tune many years ago:
