LSD Already Installed?
Old Aug 14, 2015 | 01:25 PM
eFifty5AMG's Avatar
2004 E55
Is there a definite way to find out if I have an LSD already installed? I admit I have done a couple burnouts, out of curiosity, but they've never been "one wheel peels". What's the best/ foolproof way to find out?
Old Aug 14, 2015 | 02:04 PM
KJI3jflarryfe93's Avatar
we only have esp fitted.
lsd is an expensive aftermarket part for us to buy.
i might get a Quaife later on when the currency rate is in my favour.
do you know if there is any extra modification needed to fit the LSD into diff housing?
Old Aug 14, 2015 | 02:19 PM
eFifty5AMG's Avatar
2004 E55
Originally Posted by kowalski
we only have esp fitted. lsd is an expensive aftermarket part for us to buy. i might get a Quaife later on when the currency rate is in my favour. do you know if there is any extra modification needed to fit the LSD into diff housing?
Exactly, I'm aware an LSD was not installed from the factory. That's why I'm wondering if both wheels spinning is normal, or if an aftermarket LSD has already been installed possibly by a previous owner.
Old Aug 14, 2015 | 04:18 PM
Sulaco's Avatar
1999 C43 AMG, 2005 E55 Wagon
it's normal, because you're at a stand still and overpowering the ESP.
In situations where you're moving is when it ruins everything and goes peg-leg, costing you momentum and wheel horsepower.
Old Aug 14, 2015 | 04:23 PM
eFifty5AMG's Avatar
2004 E55
Originally Posted by Sulaco
it's normal, because you're at a stand still and overpowering the ESP. In situations where you're moving is when it ruins everything and goes peg-leg, costing you momentum and wheel horsepower.
Ok thanks, I get what you're saying. At what point does it go peg-leg, a certain mph?
Old Aug 14, 2015 | 05:02 PM
cm60k's Avatar
You can use MB LSD as well, I'm using it since 4 years without any issues..
ZAYED,,
Old Aug 14, 2015 | 05:13 PM
Sulaco's Avatar
I think it's certain situations as opposed to a certain speed. Like if you can't break loose for a brake torque burnout, you can jam both pedals to the floor, then release the brake pedal for a split second and then jam on it again. This will trip up the ESP and cause only one wheel to spin while the other doesn't.
ESP is great for my wife but the worst for me.
Old Aug 14, 2015 | 07:47 PM
sick430's Avatar
CLK Cabrio
Zayed, what LSD are you running in the W202?
Old Aug 15, 2015 | 12:06 AM
cm60k's Avatar
It's from (W124 300E/300D/300TD/300CE/300E 4Matic), with ASD 3.07 diff.
to make it fit; you well need to switch side flanges from your C43 to the ASD diff.,
and should to get CLK320 rear shaft piece, to match the size of the front flange & flex disc,,
*of course this in not my idea, i took it from our good friend's "money-one"..
https://mbworld.org/forums/c36-amg-c...43-almost.html
ZAYED,,
Old Aug 17, 2015 | 03:37 PM
sick430's Avatar
CLK Cabrio
thanks, will add this to the todo list
Old Aug 19, 2015 | 12:37 PM
ProjectC55's Avatar
C43/55,2k11 Volvo S60 T6AWD,2k Audi B5 S4,95 Eagle Talon Tsi AWD 500+awhp
ZAYED,,
Didn't he also say another option was to get a diff from a w209 55/slk32 diff use a 208 cover both it up and just install a quaiffe.
https://mbworld.org/forums/c36-amg-c...ml#post4425676
https://mbworld.org/forums/c36-amg-c...ml#post4085997
