C43 HPS Supercharge needs transmission
Old Sep 2, 2015 | 03:20 AM
BlownC43's Avatar
98 C43, 965 Turbo, Cayenne Turbo, R53 Cooper S, BMW E46 M3, Audi A4 Turbo, Ferrari F355 Spyder
Hi All,
I have a 98 C43 that has 105k miles on it and the transmission finally decided to break.
I'm look for a company that does or has transmission rebuilds, hopefully in So. California.
The car is putting out an conservative 100hp & 100 ft/lbs in addition to the factory specs per HPS.
Any ideas? I've read the 722.636 is a good upgrade, but not sure if it will fit or what to change over to make it fit...
Any help would be appreciated...
Thanks GP
Old Sep 2, 2015 | 06:49 AM
DutchC54's Avatar
1998 W202 C43 ///AMG 5.4
722.636 fits, ive just done this swap 3 weeks ago since my original gearbox also blew.
u only need to swap the parking cable mechanism
and change the flange from 4-finger to 3-finger.
https://mbworld.org/forums/c36-amg-c...-c43-55-a.html
Old Sep 2, 2015 | 02:01 PM
nkctb7's Avatar
2006 E55 AMG/1996 C36 AMG/1999 C43/55 AMG/2021 Toyota Tundra Crew Max TRD Sport Premium
I suppose that it's safe to say that one should steer clear of that much added torque if they don't want to run into any transmission issues. Correct? Thx
Old Sep 3, 2015 | 08:07 PM
sick430's Avatar
CLK Cabrio
I have a trans out of an CL55 that will fit, I was going to install in my car but ended up going a different route. In SoCal (SFV).
Let me know
Old Sep 6, 2015 | 12:36 PM
ECTurboGSX's Avatar
98 C43, 15 Alfa 4C LE, 18 Tesla Model 3 DM Perf, 08 Duc S1000, 02 Duc 998, 98 Duc 748, 01 Miata
Depending on how far you want to go (and how much money you want to spend), the SRT8's use a 722.6 based transmission and there are builders for those:
http://www.paramountperformanceshop....ory_s/1819.htm
Old Nov 3, 2015 | 03:57 AM
Blown4door's Avatar
E63, 190e, s400
would you consider selling the car?
Old Jan 25, 2016 | 07:30 PM
BlownC43's Avatar
Sorry to revive the topic, i'm been so busy and left this repair on hold. So does anyone know a source for a 722.636?
I've spoken to Mark at Sun Valley Mercedes and he wants to rebuild ir exchange mine..approx 2k in costs.
Thanks...
Old Jan 26, 2016 | 09:11 AM
Sulaco's Avatar
1999 C43 AMG, 2005 E55 Wagon
Thanks...
Used to run well over 5 grand to do these transmissions. I have paperwork on file where mine had a new tranny and tcu in 05 for 8 grand.
Old Jan 26, 2016 | 01:11 PM
sick430's Avatar
CLK Cabrio
I have a trans out of an CL55k that will fit, I was going to install in my car but ended up going a different route. In SoCal (SFV). Has about 37K miles on it
Let me know
Old Mar 2, 2016 | 08:50 PM
BlownC43's Avatar
Sick430, pm'd you...
Old Nov 27, 2016 | 04:46 PM
John Hicks III's Avatar
2003 CL55 AMG
POSSIBLY Looking for tranny for 2003 CL55 AMG
Let me know
few days ago I was driving and out of nowhere the car just slipped into neutral. There was no lights on the dashboard no warning signs. So I freaked out a little bit because I had just got my car back after replacing the water pump two days prior. so now I'm sitting there in the middle of the street and the car is just revving... so I put the car back and park turn the car off. And I wait about a minute. Then I start the car and I start shifting the gears to see if the car changes sounds as I do so. Which it does. So I put it in drive and the car drives normal for about 20 seconds and then I hear a slight whine and it slipped back into neutral. I have no idea what it could be but I need to get something done about it ASAP
Old Nov 28, 2016 | 05:10 AM
Junel Doc's Avatar
E55 w211, S63 w221 ,G550/G63 bodykit, Ferrari F430
i just had this same problem today.
Old Nov 29, 2016 | 10:40 PM
2003 CL55 AMG
I just dropped my pen for my transmission and the were shavings in it. So it looks like debris was getting sucked up into the filter and causing the transmission to slip out of gear. The car has 170k miles on it so this was inevitable. When they opened up the transmission they saw that the converter was all torn up and needed to be replaced. So that solves that problem.... total cost to rebuild is 1600 at
foothill transmission specialists in Pamona
Old Nov 29, 2016 | 10:41 PM
2003 CL55 AMG
Let me know
do you still have this tranny? If so ..please txt me at 786-356-5080
Old Sep 27, 2017 | 06:02 PM
CamaroMike's Avatar
2004 E500
We have a 2004 E500 4Matic, 133,000 miles and the only major stuff thats happened is the front air struts. Other than that, its just normal maintenance... new tires, new brakes, new brake sensors. No leaks, no motor issues of any kind.
Little Glitches? Have the oscillating power locks on the passenger side. Probably too expensive to fix as car still locks fine. Also the dash computer, starts up asking if emission inspection has been done on schedule? Searching for that computer reset that lets you clear all that bunk.
Old May 21, 2019 | 11:38 AM
Gersh320's Avatar
E320 & X166
235k and counting. Love it just as much as I did on day one!
Old May 22, 2019 | 12:25 AM
Benzrider17's Avatar
C43 c55 C63
Sun valley in Cali that’s where I got mine last year $2k and everything worked out perfect cars been running great lots of power
Old Oct 25, 2019 | 12:04 AM
C$#'s Avatar
C$#
2018 C43 AMG
Wrong form oops
Old Oct 27, 2019 | 04:29 AM
Schwayz's Avatar
'14 E63S DESIGNO DIAMOND WHITE, '99 C43 SILVER
Let me know
DO you still have?
Old Jan 9, 2020 | 09:48 AM
Dokus's Avatar
W211 e500 (Sold), w204 c180, w203 c180, w201 190e, W219 CLS 55
Wrong thread
Old Jan 18, 2020 | 09:57 PM
Juice33's Avatar
2005 Porsche 911 Turbo & 2018 Tacoma TRD Pro
Did you guys have the transmission serviced prior to the issues or did you not do anything as per MB's original service timelines?
Old Aug 21, 2020 | 07:01 AM
SlyOne's Avatar
2015 C300 4matic
New member here! Thanks for all the information posted on this thread. Does anyone know if the C300 has identical front inner clearance?
Old Mar 11, 2021 | 09:12 PM
Bankroll's Avatar
E55 AMG
Is the E55 AMG, the best Mercedes ever?
Old Jun 8, 2021 | 10:26 PM
aaronBLUEeyes's Avatar
‘17 C43 AMG, ‘10 C300 4MATIC Sport (previous)
Moderator please delete, wrong thread.
Old Oct 31, 2021 | 08:26 PM
Abet15's Avatar
C43 2019
Hi guys.
will we sit on my C43 2019 wheels in this setup?
2x 8.5 JX 19 ET 38 tires 225/40
2x 9.5 JX 19 ET 56 tires 255/35
The wheels should be OEM from C63
Thanks for the advice, I'm a beginner and I don't know what to do
