What lug bolts to use with my Monoblock 18s? And where to buy Hub Rings?
Old Feb 16, 2016 | 07:30 PM
BolivianFuego's Avatar
1999 C280
Hi Guys,
C280 guy here, but no one is responding to my thread on that side of the site. I'd imagine you guys would have more experience with Monoblocks.
I get vibration from my Monoblocks when on my 1999 C280 but don't have hub rings in them. I have the stock 15s on right now though, and I have NO issues with the vibration I get.
I am assuming it's no hub rings. Where do I get them to fix my issues and what Lug Screws work best for my application? I am using the stock lugs...but don't think they are ideal.
Any advice would be GREATLY appreciated! Thank you
Old Feb 16, 2016 | 07:57 PM
PJmak's Avatar
Most mercedes cars at least from our era use same wheel bolts.
Trust me. I searched for longer wheel bolts when I got my spacers.
Chances are your tires are not balanced or the wheels are bent. Stock bolts should be fine.
Old Feb 16, 2016 | 08:04 PM
1999 C280
You don't think it's hub rings? I didn't have any hub rings when I was using them.
Appreciate the input!
Edit: Forgot to add in, I had the wheels professionally straightened and refinished. They were balanced and everything prior to putting on the car.
Old Feb 16, 2016 | 10:28 PM
1999 C280
OK...been searching like crazy about the lug nuts. My car and C43/C36 have the M12 seat. That should be the same seat that came off the same AMG wheels this size, right?
Since they are the staggered versions, these came off the E55's I believe.Can anyone confirm? Sooo hard to find information.
Old Feb 16, 2016 | 11:27 PM
PJmak's Avatar
This is the part number for stock c43 amg lug nuts.
I use same ones on my 18" monoblocks.
000-990-48-07-M36
Old Feb 16, 2016 | 11:29 PM
PJmak's Avatar
I would go to LesSchwab and have them do road force wheel/tire balancing.
Not all shops have the equipment for this but they do. Its $49 to do it but it will tell you wether your wheels are bent, balanced right or if the tires are worn off weird
Old Feb 17, 2016 | 10:58 AM
1999 C280
Thanks! Unfortunately...I don't have one in Virginia.
I am using my stock 12M lugs...and at first I thought I needed M14, but now that I looked into it and see that these wheels came off a E55, those used M12s too!
So maybe I don't need new lugs?? I just worry about hte hub ring since the lugs itself are the ones that are holding the wheel on and the Hub isn't helping at all.
Maybe that's the vibration?
Old Feb 20, 2016 | 02:58 AM
ECTurboGSX's Avatar
98 C43, 15 Alfa 4C LE, 18 Tesla Model 3 DM Perf, 08 Duc S1000, 02 Duc 998, 98 Duc 748, 01 Miata
The hub size shouldn't be any different. 66.5 mm for both the 202 and 210. See the following link for centerbore size and bolt pattern for most Mercedes:
http://www.alloywheelsdirect.net/mercedes_alloy_wheels
Old Feb 20, 2016 | 12:18 PM
kbob999's Avatar
'20 X5 M50i; '17 Ram 3500; Golf Cart; Bikes; Scooters
I got hub rings from Tirerack.com
Just call them, they were cheap and fast.
And it did fix my imbalance issue on my Benz.
If you do have a Les Schwab, you are in luck. They are the best tire store hands down. Stunning service.
Old Feb 22, 2016 | 01:59 PM
1999 C280
Awesome!! Thanks for teh link....but I can;t seem to see the centerbore size or Bolt Pattern.
http://www.alloywheelsdirect.net/mer...g_ii_wheel_193
Thanks!! I will call them to see if they can help me out.
Old Feb 23, 2016 | 12:47 AM
mbsickness's Avatar
1996 C36
The Monoblocks from a w210 E55 will not need centering rings as the hubs from the w202 and w210 cars are the same. Lug bolts are also the same. any vibration issues lie with the, rim, tire, or balance.
Old Feb 23, 2016 | 10:34 AM
1999 C280
Thank you for the clarification!
Old Feb 23, 2016 | 07:41 PM
1999 C280
So....I just came back from the shop where the wheels are right now.
The guy measured it for me and said the inside of it is 70.2 I think he said? So that means there's about 5mm difference from 66.5.
Does that sound right?? Maybe these didn't come off a 00 or 01 E55....
Thoughts?
