Clicking coming from rear end/new wheels on!
Old May 1, 2016 | 09:56 AM
99CEEFOURTHREE's Avatar
99 c43,90 mustang gt supercharged convertible,07 acura tl type s, Hummer H3t pickup
So I just installed my 18'' c63 wheels on my 43.Front are 18x8 et 35 rear are 18x9 et 35.They fit perfect.The rears I pushed out slightly with a 5mm hubcentric aluminum wheel spacer from the wheel dealer I purchased the rims from.They sell tons of Benz wheels and parts so they know there stuff.I NOW HAVE A CLICKING SOUND FROM THE REAR.I tourqued the wheels properly and flipped the ring several times still the clicking is present.Nothing is rubbing was under the car checked wheel clearence,tire clearance,caliper clearance etc.Could it be the flex disc or anything else? Im baffled.Not sure if sound wasn't present before the wheel change as my car sits for long periods of time in the garage.Last time I had driven it was two months ago in winter with all windows rolled up,so if it wasn't present I probably couldn't hear it.
Old May 1, 2016 | 10:08 AM
Some pic's
Old May 1, 2016 | 10:11 AM
Some Pic's of the c63 wheels.
cm60k's Avatar
Nice Choice, Soooo GORGEOUS..,,
just need a Black cover for Bolts..
ZAYED,,
Old May 1, 2016 | 10:16 AM
Yes thanks! Sorry for double post
Old May 1, 2016 | 10:20 AM
DutchC54's Avatar
1998 W202 C43 ///AMG 5.4
beautiful set of rims!!
but why u didnt u go for 255/35 R18?
looks even more "bad-***" from the back.
about the clicking noise... could it be possible that the bolts which are used now touch the e-brake stuff behind the disk? i think i see u used the oem ones which are quite long.
anyway love the look!!!
Old May 1, 2016 | 10:33 AM
Thanks..Had these Tires so I used them and saved a ton of cash. 245-35-18..Yes used the stock bolts...but me putting the spacer on would have shortend the bolts no?
Old May 1, 2016 | 10:41 AM
DutchC54's Avatar
yes normally yes..
but i dont know how thick the "meat" is on these rims..
just a couple of mm's can make a click/tick sound.
but again this is me thinking out-loud.
normally changing rims doest make a different is all is free and there is no rubbing anywhere.
Old May 1, 2016 | 10:47 AM
You mean the hub face on the rear...it is very thin..that could be the issue.What is the size of our lugs? I read somewhere that a minimum 6 1/2 turns to tighten lugs is sufficient..Im almost sure I was way beyond that....sooo..
Old May 1, 2016 | 11:18 AM
Ok measured hub face thickness on stock monos,,and yes the new wheels are much thinner..stuck lug thru mono and new wheel for comparison and the lugs sit longer on the new wheel so that's probably it.The fronts are a non issue noise wise.Where can I get shorter lugs,or can I use wheel lug washers to shorten up?
Old May 1, 2016 | 11:51 AM
cm60k's Avatar
Also important notice;-
Can't use stock (M12) bolts with these nice C63 Rims, cause the bolt hole is bigger, and the bolt head should be (R14)..!
if you keep your stock (M12), it will damage the base of the bolt hole, have to go with (M12) with (R14) bolt head..!!
ZAYED,,
Old May 1, 2016 | 11:56 AM
ZAYED,,
ok Zayed...I checked with my wheel guy he said lugs are a touch long and to shave a mm off problem solved...so I need to get THE LUGS WITH R14 BOLT HEADS?
Old May 1, 2016 | 12:12 PM
eFifty5AMG's Avatar
2004 E55
Car looks great brother
If you need R14 your fronts would need changing too. But you're not getting any odd behavior from them? You probably already checked, but also look at the lugs for ball head vs. cone to make sure they match.
Old May 1, 2016 | 01:49 PM
mickey13's Avatar
1999 AMG C43
nice nice nice!
Old May 1, 2016 | 03:42 PM
Fixed the clicking...Good call Dutch54..shaved about a thread off each rear lug nut,Re Tourqed to 90ft.lb and clicking is gone!
Old May 1, 2016 | 03:43 PM
Originally Posted by mickey13
nice nice nice!
Thanks Buddy
Old May 1, 2016 | 03:48 PM
Thanks buddy!...cone is what these wheels are machined for,checked them well.Running the stock ones for now until I find the black lugs I want.The 12's seat well into the wheels.Took her up to 130 and tracks straight as stock.
Old May 2, 2016 | 03:12 AM
DutchC54's Avatar
good to hear the clickticking is gone!!!
happy driving!!!
Old May 2, 2016 | 07:52 AM
KJI3jflarryfe93's Avatar
same thing happened to me when i bought my Brabus rims
i had to shorten my bolts a lill bit as they were touching my hand/foot brake pads giving a click sound.
if you drive your car you will ruin your hand/foot brake pads.
fix your problem b4 you drive your car
Old May 10, 2016 | 06:18 PM
YES SIR! Did that and everything is a go...Now to find our lugs in black finish.
Old May 11, 2016 | 11:13 AM
PJmak's Avatar
You might wanna check if you ruined your parking brake.
Check if there is heat or smell coming from the rear wheels after even short periods of driving.
Old May 11, 2016 | 11:15 AM
or try an incline if your P-brake holds car in place?
Old May 11, 2016 | 07:37 PM
I rolled down the driveway about 10 feet and crept back up..never drove the car..just backed out slowly and pulled forward a few times..doubt I damaged anything doing that lol
